[postgis-users] RE Importing shapefiles to PostGIS
Ben Madin
lists at remoteinformation.com.au
Fri Jan 29 01:15:43 PST 2010
Shreerang,
Here is a quick example of how it looks for me:
minmin:~ $ shp2pgsql -s 4326 -I /Users/minmin/Spatial/country/AUS/australia.shp public.australia > australia.sql
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
minmin:~ $ psql australiapsql (8.4.2)
Type "help" for help.
australia=# \i ./australia.sql
SET
BEGIN
psql:./australia.sql:14: NOTICE: CREATE TABLE will create implicit sequence "australia_gid_seq" for serial column "australia.gid"
psql:./australia.sql:14: NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index "australia_pkey" for table "australia"
CREATE TABLE
addgeometrycolumn
public.australia.the_geom SRID:4326 TYPE:MULTIPOLYGON DIMS:2
(1 row)
INSERT 0 1
CREATE INDEX
COMMIT
australia=# VACUUM ANALYZE australia;
VACUUM
australia=# \dt
List of relations
Schema | Name | Type | Owner
public | geometry_columns | table | ben
public | spatial_ref_sys | table | ben
public | australia | table | ben
You may want to actually check inside the .sql file you have written to find the commands it created, and try copy / paste them into the psql console if it really isn't working.
cheers
Ben
On 29/01/2010, at 14:18 , Shreerang Patwardhan wrote:
> Hello Ben,
> Ya!! There are no more authentication errors!! But how do I verify that my data has been uploaded to postgis? In pgadmin I can't see any tables in my database- testdb. However, if I use the PSQL utility in pgadmin for testdb then I am able to see the contains of the 2 tables. Is this sufficient to verify that the data has been loaded into postgis? If not, then pleasse suggest something to verify..
> Thanx,
> Shreerang.
> postgis-users mailing list
