[postgis-users] MySQL -> Postgresql - habitat column name
Michael A. Peters mpeters at shastaherps.org
Thu Jul 15 11:37:39 PDT 2010
I'm currently working on a migration of my web site to postgresql so that
I can use PostGIS.
I'm still working on the devel side but basically -
mysqldump database > dump.sql
perl mysql2pgsql.perl dump.sql load.sql
psql database < load.sql
does the trick, now it's cleaning up my sql in my code.
I used MDB2 so once I finally figured out how to make a web user with
necessary permissions most of it "just worked" but - I had a table with a
column named habitat. On a query on that table, query failed. When
manually applying the query, it said habitat did not exist.
I looked in the load file (there's no describe table ??) and habitat was
changed to habyteaat but I can find nothing about habitat being a special
word to postgresql. Is that a bug in the perl script I can just sed to fix
the output or do I really need to use a different column name?
Michael A. Peters
http://www.shastaherps.org/
