[postgis-users] Error loading lwpostgis.sql
Michael A. Peters mpeters at shastaherps.org
Fri Jul 16 17:06:37 PDT 2010
I'm using CentOS 5.4 up to patch level. Pretty much stock CentOS + EPEL.
Only have updated php which shouldn't effect postgresql and a gnome
library that had a bug (and there I patched the src.rpm, same version as
stock). I usually don't like to replace vendor provided stuff.
postgresql-8.1.11-1.el5_1.1
postgis-1.3.2-1.el5
It's a 32-bit install if it matters.
As the postgres user I run the following command:
psql -d shastaherps -f /usr/share/pgsql/contrib/lwpostgis.sql 2> error.log
In error.log I find the following:
psql:/usr/share/pgsql/contrib/lwpostgis.sql:2356: ERROR:  language
"plpgsql" does not exist
That is then followed by a bunch of "current transaction is aborted"
messages.
Is there a step I missed?
Michael A. Peters
http://www.shastaherps.org/
