[postgis-users] Check geometry for true intersection using ST_Relate
Andrea Peri 2007 aperi2007 at gmail.com
Sun Jul 18 03:44:37 PDT 2010
I need to retrieve from a table all the geometry that intersect a given
polygon .
But the standard ST_Intersection is no good for me because it return
true even if
two geometry are only touching on their boundary without having a
partially overlap each other.
I don't find other type of intersection that don't responde true on touch.
So I try to use the ST_Relate(..)
But I don't understand exactly how define the matrix to use.
I don't sure if the correct matrix to declare is this
String overlaps = "T********";
or this
String overlaps = "2********";
my geometry are all polygon so perhaps declaring
can be sufficient ?
Many thx,
Andrea Peri.
