[postgis-users] problem installing WKTRaster
Sebastian E. Ovide sebastian.ovide at gmail.com
Mon Jul 19 02:01:18 PDT 2010
Hi All,
on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
Just followed the instructions from WKTRaster 0.1.6d readme.txt and when I'm
running the rtpostgis.sql I'm getting this error:
NOTICE:  type "raster" is not yet defined
DETAIL:  Creating a shell type definition.
ERROR:  could not load library "C:/Program
Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
found.
********** Error **********
found.
SQL state: 58P01
But I do have that file !!!!
C:\Documents and Settings\sebastian ovide>dir "C:\Program
Files\PostgreSQL\8.4\lib\rtpostgis.dll"
 Volume in drive C has no label.
 Volume Serial Number is 2079-A57D
 Directory of C:\Program Files\PostgreSQL\8.4\lib
21/06/2010  13:52           210,432 rtpostgis.dll
               1 File(s)        210,432 bytes
               0 Dir(s)  450,924,576,768 bytes free
now, If I use the backslash... ( as for the error)
C:\Documents and Settings\sebastian ovide>dir "C:/Program
File Not Found
ideas ?
thanks
Sebastian E. Ovide
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100719/30d7e164/attachment.html>
