[postgis-users] problem installing WKTRaster
George Silva
georger.silva at gmail.com
Mon Jul 19 09:52:07 PDT 2010
It worked just fine. Thanks.
George
On Mon, Jul 19, 2010 at 1:50 PM, George Silva <georger.silva at gmail.com>wrote:
> Yeap Pierre, this is 8.3.
> I'll do that and i'll get back to you. Thanks for the quick answer.
> George
> On Mon, Jul 19, 2010 at 1:27 PM, Pierre Racine <
> Pierre.Racine at sbf.ulaval.ca> wrote:
>> You’re using PostgreSQL 8.3 right?
>> Replace
>> “SELECT ST_Intersection((gv).geom, $1) intgeom”
>> with
>> “SELECT ST_Intersection((gv).geom, $1) AS intgeom”…
>> I’ll fix the source.
>> Pierre
>> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
>> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *George
>> Silva
>> *Sent:* 19 juillet 2010 12:11
>> *To:* PostGIS Users Discussion
>> *Subject:* Re: [postgis-users] problem installing WKTRaster
>> While we are at it, I've tried installing and there it complains about an
>> error here:
>> My download link was:
>> http://www.postgis.org/download/windows/pg83/experimental/wktraster/wktraster_pg83.zip
>> I've already placed all my files at the correct place. What is the name of
>> the environment variable for postgresql? Just "PATH"? I already have two or
>> three variables with that name...
>> Any ideas? Thanks guys.
>> CREATE OR REPLACE FUNCTION st_intersection(geom geometry, rast raster,
>> band integer)
>> RETURNS SETOF geomval AS
>> -- Return the intersections of the geometry with the vectorized
>> parts of
>> -- the raster and the values associated with those parts, if
>> really their
>> -- intersection is not empty.
>> SELECT intgeom, val
>> FROM (
>> SELECT ST_Intersection((gv).geom, $1) intgeom, (gv).val
>> FROM ST_DumpAsPolygons($2, $3) gv
>> WHERE ST_Intersects((gv).geom, $1) AND ST_Intersects($1, $2,
>> $3)) foo
>> WHERE NOT st_isempty(intgeom) -- eliminate empty intersections
>> UNION ALL
>> -- If the geometry does not intersect with the raster, return an
>> empty
>> -- geometry and a null value
>> SELECT emptygeom, NULL FROM
>> ST_GeomCollFromText('GEOMETRYCOLLECTION EMPTY', st_srid($1))
>> emptygeom
>> WHERE NOT ST_Intersects($1, $2, $3);
>> LANGUAGE SQL IMMUTABLE;
>> NOTICE: type "raster" is not yet defined
>> DETAIL: Creating a shell type definition.NOTICE: argument type raster is
>> only a shell
>> ERROR: syntax error at or near "intgeom"
>> LINE 1219: SELECT ST_Intersection((gv).geom, $1) intgeom, (...
>> ********** Error **********
>> SQL state: 42601
>> Character: 44614
>> On Mon, Jul 19, 2010 at 12:37 PM, Paragon Corporation <lr at pcorp.us>
>> wrote:
>> Sebastian,
>> Oops sorry about that. Will correct the readme.txt.
>> Leo
>> http://www.postgis.us
>> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Sebastian
>> E. Ovide
>> *Sent:* Monday, July 19, 2010 9:08 AM
>> Re reading the readme.txt
>> 1) Install PostGIS into your database if you haven't already
>> 2) Copy the rtpostgis.dll to the lib folder of your PostgreSQL install
>> 3)
>> a) then Run the share\contrib\postgis\rtpostgis.sql in your postgis
>> enabled db
>> b) You can install help now too by running
>> share\contrib\postgis\wktraster_comments.sql
>> 4) Copy the contents of bin to your PostgreSQL bin folder
>> (gdal2wktraster.py, libgdal.dll) to bin folder of your PostgreSQL install.
>> the point 4 should come before the point 3....
>> On Mon, Jul 19, 2010 at 12:13 PM, Sebastian E. Ovide <
>> sebastian.ovide at gmail.com> wrote:
>> Hi Fred,
>> Thanks to that Tool I've discovered that the dll could not find
>> libgdal.dll... so I've copied it into the bin dir and now it works !
>> thanks !
>> On Mon, Jul 19, 2010 at 12:03 PM, Fred Lehodey <lehodey at gmail.com> wrote:
>> Hi Sebastian,
>> you can try that free utility : http://www.dependencywalker.com/
>> Sometimes helpful to discover a missing file.
>> Fred.
>> On Mon, Jul 19, 2010 at 11:56 AM, Sebastian E. Ovide <
>> same:
>> ERROR: could not load library "C:/Program
>> Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
>> found.
>> 2010/7/19 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> On Mon, Jul 19, 2010 at 11:32 AM, Sebastian E. Ovide
>> <sebastian.ovide at gmail.com> wrote:
>> > done, same problem
>> be
>> > found.
>> Try adding C:/Program Files/PostgreSQL/8.4/lib/ to the PATH enviroment
>> variable.
>> >> On Mon, Jul 19, 2010 at 11:01 AM, Sebastian E. Ovide
>> >> > Hi All,
>> >> > on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
>> >> > Just followed the instructions from WKTRaster 0.1.6d readme.txt and
>> when
>> >> > I'm
>> >> > running the rtpostgis.sql I'm getting this error:
>> not
>> >> > be
>> >> > found.
>> not
>> >> > be
>> >> > found.
>> >> > SQL state: 58P01
>> >> > But I do have that file !!!!
>> >> > C:\Documents and Settings\sebastian ovide>dir "C:\Program
>> >> > Files\PostgreSQL\8.4\lib\rtpostgis.dll"
>> >> > Volume in drive C has no label.
>> >> > Volume Serial Number is 2079-A57D
>> >> > Directory of C:\Program Files\PostgreSQL\8.4\lib
>> >> > 21/06/2010 13:52 210,432 rtpostgis.dll
>> >> > 1 File(s) 210,432 bytes
>> >> > 0 Dir(s) 450,924,576,768 bytes free
>> >> > now, If I use the backslash... ( as for the error)
>> >> > C:\Documents and Settings\sebastian ovide>dir "C:/Program
>> >> > File Not Found
>> >> > ideas ?
>> >> > thanks
>> >> > Sebastian E. Ovide
>> >> Hi,
>> >> Try copying rtpostgis.dll in C:\Program Files\PostgreSQL\8.4\bin
>> directory
>> >> Best regards,
>> >> Jorge Arévalo
>> >> DEIMOS Space
>> >> Internet & Mobilty Division
>> >> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
>> >> 28760 Tres Cantos (Madrid)
>> >> Tel: +34 91 806 34 50 - ext: 155
>> >> http://gis4free.wordpress.com
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> > Sebastian E. Ovide
>> Jorge Arévalo
>> DEIMOS Space
>> Sebastian E. Ovide
>> skype: sebastian.ovide
>> +353 (0) 87 6340149
>> Sebastian E. Ovide
>> Sebastian E. Ovide
>> George R. C. Silva
>> Desenvolvimento em GIS
>> http://blog.geoprocessamento.net
> George R. C. Silva
George R. C. Silva
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100719/3546ac24/attachment.html>
