[postgis-users] WKTRaster : gdal2wktraster.py cannot read AIG/Arc/Info Binary Grid
Peter Baumann p.baumann at jacobs-university.de
Tue Jul 20 08:32:03 PDT 2010
Sebastian,
if you don't want to work with zillions of tiles, but with large
mosaics, check out www.rasdaman.org :
single tile insert (any size; fully transparent tiling, indexing, query
optimization):
single tile read (any size):
$ rasql -q "select png(m) from MyImages as m where oid(m)=42" --out file
change RGB to greyscale:
$ rasql -q "select png( 0.3*m.red+0.59*m.green+0.11*m.blue) from
MyImages as m"
retrieval from any-size mosaic:
$ rasql -q "select png(m[x0:x1,y0:y1]) from MyImages as m"
Same from C++ and Java API.
It's proven, any-size, cloud-scalable, and open source.
-Peter
On 07/20/2010 04:46 PM, Sebastian E. Ovide wrote:
> yes... with png worked... but it was a different png (a smaller one)...
> so I've converted the ESRI into a png and tried to import it... and it
> didn't work neither...
> so this is the situation:
> A have huge rusters (from 150kx150k).. In Oracle I would just load it
> (the huge raster) in a single row of a GeoRaster table and then Oracle
> GeoRaster would split it in small tiles and store one tile per line of
> another table (Raster Data Table)... then I can run a query similar to
> this one: SELECT getcellvalue(t.rastercolumn,x,y) from GeoRasterTable
> t where t.id <http://t.id>=1; and GeoRaster will query automatically
> the spatial indexes and the Raster Data Table and it will find the
> right tile etc...
> I do not know how WKTRaster works.... If I cannot import a such big
> image, of course I can split it in smaller georeferenced tiles...
> (how?)... but.... My main question is: after that, how will the table
> look like ? how can I do the same query (where id=1 or where name="UK"
> etc...) ?
> On Tue, Jul 20, 2010 at 2:31 PM, Pierre Racine
> <Pierre.Racine at sbf.ulaval.ca <mailto:Pierre.Racine at sbf.ulaval.ca>> wrote:
>     Wait. You first said the png was working. Now it’s not? Did you
>     try gdal_translate with the ESRI grid? For sure I haven’t test yet
>     with such big rasters. Is this the result of a merge or all your
>     original raster are all this size? The point is that with WKT
>     Raster you don’t have to merge your raster first into a gigantic
>     raster in order to get it store in a unique table like with Oracle
>     Spatial.
>     Pierre
>     *From:* postgis-users-bounces at postgis.refractions.net
>     <mailto:postgis-users-bounces at postgis.refractions.net>
>     [mailto:postgis-users-bounces at postgis.refractions.net
>     <mailto:postgis-users-bounces at postgis.refractions.net>] *On Behalf
>     Of *Sebastian E. Ovide
>     *Sent:* 20 juillet 2010 05:51
>     *To:* PostGIS Users Discussion
>     *Subject:* Re: [postgis-users] WKTRaster : gdal2wktraster.py
>     Hi Pierre,
>     Does gdal2wktraster.py have any limitation on the maximum number
>     of columnsxrows ?
>     in my case, my raster is  107759 x 168633...
>     gdal works well:
>     sebas at SeansPC:~/rasters$ gdal_translate -of PNG raster/ test.png
>     Input file size is 107759, 168633
>     0...10...20...30...40...50...60...70...80...90...100 - done.
>     sebas at SeansPC:~/rasters$ python gdal2wktraster.py -r raster/ -t
>     sebastable -o ok.sql
>     gdal2wktraster.py:695: DeprecationWarning: 'H' format requires 0
>     <= number <= 65535
>       hexwkb += wkblify('H', xsize)
>     gdal2wktraster.py:696: DeprecationWarning: 'H' format requires 0
>     <= number <= 65535
>       hexwkb += wkblify('H', ysize)
>     gdal2wktraster.py:727: DeprecationWarning: integer argument
>     expected, got float
>       hexwkb += wkblify(pt2fmt(pixtype), nodata)
>     Traceback (most recent call last):
>       File "gdal2wktraster.py", line 1013, in <module>
>         main()
>       File "gdal2wktraster.py", line 976, in main
>         wkblify_raster(opts, filename, i)
>       File "gdal2wktraster.py", line 921, in wkblify_raster
>         summary = wkblify_raster_level(options, ds,
>     options.overview_level, band_range, infile, i)
>       File "gdal2wktraster.py", line 888, in wkblify_raster_level
>         hexwkb += wkblify_band(options, band, level, xoff, yoff,
>     read_block_size, block_size, infile, b)
>       File "gdal2wktraster.py", line 777, in wkblify_band
>         target_block_size[0], target_block_size[1])
>       File "/usr/lib/python2.6/dist-packages/osgeo/gdal.py", line 895,
>     in ReadAsArray
>         buf_xsize, buf_ysize, buf_obj )
>       File "/usr/lib/python2.6/dist-packages/osgeo/gdal_array.py",
>     line 228, in BandReadAsArray
>         ar = numpy.empty([buf_ysize,buf_xsize], dtype = typecode)
>     MemoryError
>     sebas at SeansPC:~/rasters$ python gdal2wktraster.py -r test.png  -t
>     <= number <= 65535
>     <= number <= 65535
>     expected, got float
>         main()
>     in ReadAsArray
>     MemoryError
>     On Mon, Jul 19, 2010 at 5:56 PM, Pierre Racine
>     wrote:
>     Hi Sebastian,
>     I can convert ESRI Grid file to .sql without problem using
>     gdal2wktraster.py and the same parameters as you. I can do both
>     integer and floating point rasters.
>     Maybe this is a GDAL problem. Try to convert it using
>     gdal_translate (to tiff for example). This would be a better test
>     than just gdalinfo.
>     Could you provide us with a file sample?
>     Pierre
>     *Sent:* 19 juillet 2010 12:28
>     *Subject:* [postgis-users] WKTRaster : gdal2wktraster.py cannot
>     Hi All,
>     trying to create a SQL with gdal2wktraster.py. It works on PNG but
>     it doesn't on AIG files...
>     Note: As Gdal works fine.
>     C:\Program Files\PostgreSQL\8.4\bin>gdalinfo c:\tmp\raster
>     Driver: AIG/Arc/Info Binary Grid
>     Files: c:\tmp\raster
>            c:\tmp\raster\dblbnd.adf
>            c:\tmp\raster\hdr.adf
>            c:\tmp\raster\metadata.xml
>            c:\tmp\raster\prj.adf
>            c:\tmp\raster\sta.adf
>            c:\tmp\raster\vat.adf
>            c:\tmp\raster\w001000.adf
>            c:\tmp\raster\w001000x.adf
>            c:\tmp\raster\w001001.adf
>            c:\tmp\raster\w001001x.adf
>            c:\tmp\raster\z001001.adf
>            c:\tmp\raster\z001001x.adf
>            c:\tmp\raster\z001002.adf
>            c:\tmp\raster\z001002x.adf
>            c:\tmp\raster\z001003.adf
>            c:\tmp\raster\z001003x.adf
>            c:\tmp\raster\z001004.adf
>            c:\tmp\raster\z001004x.adf
>            c:\tmp\raster\z001005.adf
>            c:\tmp\raster\z001005x.adf
>            c:\tmp\raster\z001006.adf
>            c:\tmp\raster\z001006x.adf
>            c:\tmp\raster\z001007.adf
>            c:\tmp\raster\z001007x.adf
>            c:\tmp\raster\z001008.adf
>            c:\tmp\raster\z001008x.adf
>            c:\tmp\raster\z001009.adf
>            c:\tmp\raster\z001009x.adf
>            c:\tmp\raster\z001010.adf
>            c:\tmp\raster\z001010x.adf
>            c:\tmp\raster\z001011.adf
>            c:\tmp\raster\z001011x.adf
>            c:\tmp\raster\z001012.adf
>            c:\tmp\raster\z001012x.adf
>            c:\tmp\raster\z001013.adf
>            c:\tmp\raster\z001013x.adf
>            c:\tmp\raster\z001014.adf
>            c:\tmp\raster\z001014x.adf
>            c:\tmp\raster\z001015.adf
>            c:\tmp\raster\z001015x.adf
>     Size is 107759, 168633
>     Coordinate System is:
>     PROJCS["unnamed",
>         GEOGCS["Unknown datum based upon the Airy 1830 ellipsoid",
>             DATUM["Not_specified_based_on_Airy_1830_ellipsoid",
>                 SPHEROID["Airy 1830",6377563.396,299.3249646,
>                     AUTHORITY["EPSG","7001"]],
>                 AUTHORITY["EPSG","6001"]],
>             PRIMEM["Greenwich",0,
>                 AUTHORITY["EPSG","8901"]],
>             UNIT["degree",0.01745329251994328,
>                 AUTHORITY["EPSG","9122"]],
>             AUTHORITY["EPSG","4001"]],
>         PROJECTION["Transverse_Mercator"],
>         PARAMETER["latitude_of_origin",49],
>         PARAMETER["central_meridian",-2],
>         PARAMETER["scale_factor",0.9996012717],
>         PARAMETER["false_easting",400000],
>         PARAMETER["false_northing",-100000],
>         UNIT["METERS",1]]
>     Origin = (128110.000000000000000,813270.000000000000000)
>     Pixel Size = (5.000000000000000,-5.000000000000000)
>     Corner Coordinates:
>     Upper Left  (  128110.000,  813270.000) (  6d29'37.32"W, 57d
>     7'47.53"N)
>     Lower Left  (  128110.000,  -29895.000) (  5d45'40.00"W,
>     49d34'10.24"N)
>     Upper Right (  666905.000,  813270.000) (  2d24'41.72"E, 57d
>     7'58.04"N)
>     Lower Right (  666905.000,  -29895.000) (  1d41'32.29"E,
>     49d34'18.23"N)
>     Center      (  397507.500,  391687.500) (  2d 2'15.04"W,
>     53d25'18.19"N)
>     Band 1 Block=256x4 Type=Byte, ColorInterp=Undefined
>       Min=1.000 Max=4.000
>       NoData Value=255
>     C:\Program Files\PostgreSQL\8.4\bin>python gdal2wktraster.py -r
>     c:\tmp\raster -t sebastable -o c:\tmp\sebas.sql
>     gdal2wktraster.py:644: DeprecationWarning: 'H' format requires 0
>     <= number <= 65535
>       hexstr = binascii.hexlify(struct.pack(fmt_little, data)).upper()
>     gdal2wktraster.py:644: DeprecationWarning: integer argument
>     expected, got float
>     ERROR 2: Multiplication overflow : 107759 * 168633 * 1
>         main()
>       File "C:\OSGeo4W\apps\gdal-16\pymod\osgeo\gdal.py", line 835, in
>     ReadAsArray
>       File "C:\OSGeo4W\apps\gdal-16\pymod\osgeo\gdal_array.py", line
>     140, in BandReadAsArray
>         ar = numpy.reshape(ar, [buf_ysize,buf_xsize])
>       File
>     "C:\OSGeo4W\apps\Python25\lib\site-packages\numpy\core\fromnumeric.py",
>     line 116, in reshape
>         return reshape(newshape, order=order)
>     ValueError: total size of new array must be unchanged
>     Any ideas ?
>     Sebastian E. Ovide
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
>     Sebastian E. Ovide
>     skype: sebastian.ovide
>     +353 (0) 87 6340149
> Sebastian E. Ovide
Dr. Peter Baumann
  - Professor of Computer Science, Jacobs University Bremen
    www.faculty.jacobs-university.de/pbaumann
    mail: p.baumann at jacobs-university.de
    tel: +49-421-200-3178, fax: +49-421-200-493178
  - Executive Director, rasdaman GmbH Bremen (HRB 147737)
    www.rasdaman.com, mail: baumann at rasdaman.com
    tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 10xx)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100720/9c4c6d31/attachment.html>
