[postgis-users] Projection problem
Jaime Fiers
jaime.fiers at gmail.com
Sat Jul 24 04:13:45 PDT 2010
Hi Ralf.
You gave me the correct way. Thanks a lot.
Finally, I used a similar SQL, with the double transformation you said, and
result is good:
CREATE OR REPLACE VIEW vista_23030 AS
SELECT "GID", transform_geometry(transform( geom, 4326), '+proj=longlat
+ellps=WGS84 +datum=WGS84 +no_defs '::text, '+proj=utm +ellps=intl +zone=30
+units=m +towgs84=-131,-100.3,-163.4,-1.244,-0.02,-1.14 +no_defs'::text,
23030)
AS geom
FROM capa_25830;
Regards
Jaime
2010/7/23 Ralf Suhr <Ralf.Suhr at itc-halle.de>
> Hi Jaime,
> to get transformation with towgs84 parameter working you have to use wgs84
> ellipsoid. Transform from ETRS89 to wgs84 and second from wgs84 to ED50.
> ST_Transform(ST_Transform( 25830_geom, 4326), 23030)
> Gr
> Ralf
> Am Freitag 23 Juli 2010, 08:42:39 schrieb Jaime Fiers:
> > Hello guys
> > I hava a "little" problem with Postgis projection.
> > I need get a reprojected view. Original data layer is in SRS=25830
> (ETRS89
> > UTM30) and view in SRS=23030 (ED50 UTM30)
> > I try this:
> > SELECT id, transform_geometry("GEOMETRY", '+proj=utm +zone=30
> +ellps=GRS80
> > +units=m +no_defs
> +towgs84=131.0,100.3,163.4,1.2439999999999989,0.01999999999999998,1.1439999
> > 999999988,-9.39 '::text,
> > '+proj=utm +zone=30 +ellps=intl +units=m +nadgrids +no_defs'::text,
> 23030)
> > AS "GEOMETRY"
> > FROM capa_25830;
> > (If we do not include "+nadgrids" we don't get anything, but that is not
> a
> > problem).
> > I always get a +-90 meter error.
> > Can anybody help me.
> > Thanks in advance
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100724/80188603/attachment.html>
