[postgis-users] evaluation tools?
Christian Schwartze
christian.schwartze at uni-jena.de
Wed Jun 2 07:38:48 PDT 2010
Check what kind of help tables were created regarding your original table
(toast tables, toast index tables in case of variable field lengths - bytea
or varchar types for instance) Therefor, have a look to the system table
pg_class ...
Christian.
Sent: Wednesday, June 02, 2010 4:28 PM
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Subject: Re: [postgis-users] evaluation tools?
> Hi Christian,
> thanks for the quick answer.
> My result set for that query is empty though.
> B.
> Zitat von Christian Schwartze <christian.schwartze at uni-jena.de>:
>> Perhaps, one starting point may be:
>> select relpages from pg_class where relname='<your_table_name>_pk'
>> Christian
>> From: "Biddy" <newskatze at riomhphost.net>
>> Sent: Wednesday, June 02, 2010 4:13 PM
>> To: <postgis-users at postgis.refractions.net>
>> Subject: [postgis-users] evaluation tools?
>>> Hi everyone,
>>> I was wondering what is the best way in postgis to get
>>> performance/benchmark infos about your database.
>>> For example, where do I find how much physical space my index takes up
>>> or the actual table? And how do you best record how long a typical
>>> query takes - let's say I let it run for a 100 times over various
>>> parts of the dataset from a little java program, how do I best collect
>>> the times it took to execute the queries?
>>> Thanks,
>>> B.
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
