[postgis-users] evaluation tools?
Paragon Corporation
lr at pcorp.us
Wed Jun 2 10:25:03 PDT 2010
Biddy,
If you are using pgAdmin III
Navigate to
Your database
your schema
tables
Then click the statistics tab on the right side
It gives a nice summary of the size of each table in that schema
-- This article we wrote may be helpful to you too
http://www.postgresonline.com/journal/index.php?/archives/110-Determining-si
ze-of-database,-schema,-tables,-and-geometry.html
Leo and Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Biddy
Sent: Wednesday, June 02, 2010 10:28 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] evaluation tools?
Hi Christian,
thanks for the quick answer.
My result set for that query is empty though.
B.
Zitat von Christian Schwartze <christian.schwartze at uni-jena.de>:
> Perhaps, one starting point may be:
> select relpages from pg_class where relname='<your_table_name>_pk'
> Christian
> From: "Biddy" <newskatze at riomhphost.net>
> Sent: Wednesday, June 02, 2010 4:13 PM
> To: <postgis-users at postgis.refractions.net>
> Subject: [postgis-users] evaluation tools?
>> Hi everyone,
>> I was wondering what is the best way in postgis to get
>> performance/benchmark infos about your database.
>> For example, where do I find how much physical space my index takes
>> up or the actual table? And how do you best record how long a
>> typical query takes - let's say I let it run for a 100 times over
>> various parts of the dataset from a little java program, how do I
>> best collect the times it took to execute the queries?
>> Thanks,
>> B.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
