[postgis-users] Fwd: PostGIS 1.5.1 make install error
Sachin Srivastava
sachin.srivastava1984 at gmail.com
Fri Jun 4 05:46:24 PDT 2010
This was the original error i got :
/bin/mkdir -p '/home/sachin/pg9.0/lib/postgresql'
'/home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5'
make[1]: /home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5:
Command not found
make[1]: *** [installdirs] Error 127
make[1]: Leaving directory `/home/sachin/postgis-1.5.1/postgis'
make: *** [postgis-install] Error 2
The error i mention earlier (below) comes if i manually create the
/home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5 directory.
Thanks for your help.
-------- Original Message --------
Subject: PostGIS 1.5.1 make install error
Date: Fri, 04 Jun 2010 18:09:56 +0530
From: Sachin Srivastava <sachin.srivastava1984 at gmail.com>
Reply-To: sachin.srivastava1984 at gmail.com
Organization: EnterpriseDB
To: 'PostGIS Users Discussion' <postgis-users at postgis.refractions.net>
I am trying to build PostGIS 1.5.1 on CentOS 5 64 bit with PostgreSQL
9.0-beta1, geos-3.2.1 proj-4.7.0
make is successful, however in make install i get this error:
make[1]: execvp:
/home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5: Permission denied
PGHOME=/home/sachin/pg9.0
Anything I am missing here?
Regards,
Sachin Srivastava
EnterpriseDB, India
www.enterprisedb.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100604/897c435c/attachment.html>
