[postgis-users] Fwd: PostGIS 1.5.1 make install error
Wojciech Strzałka
wstrzalka at gmail.com
Fri Jun 4 05:53:41 PDT 2010
The same on my Fedora:
Linux 2.6.32.12-115.fc12.i686 #1 SMP Fri Apr 30 20:34:53 UTC 2010 i686 athlon i386 GNU/Linux
PG 9.0 beta1
I've simply compied the .so to PG libdir, *.sql to contrib, loader
tools to bin and it works but would be nice if 'make install' do that
for me
> Hi,
> This was the original error i got :
> /bin/mkdir -p '/home/sachin/pg9.0/lib/postgresql'
> '/home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5'
> make[1]: /home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5: Command not found
> make[1]: *** [installdirs] Error 127
> make[1]: Leaving directory `/home/sachin/postgis-1.5.1/postgis'
> make: *** [postgis-install] Error 2
> The error i mention earlier (below) comes if i manually create the
> /home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5 directory.
> Thanks for your help.
> -------- Original Message -------- Subject: PostGIS 1.5.1
> make install error Date: Fri, 04 Jun 2010 18:09:56 +0530
> From: Sachin Srivastava <sachin.srivastava1984 at gmail.com>
> Reply-To: sachin.srivastava1984 at gmail.com Organization:
> EnterpriseDB To: 'PostGIS Users Discussion'
> <postgis-users at postgis.refractions.net>
> Hi,
> I am trying to build PostGIS 1.5.1 on CentOS 5 64 bit with PostgreSQL
> 9.0-beta1, geos-3.2.1 proj-4.7.0
> make is successful, however in make install i get this error:
> make[1]: execvp:
> /home/sachin/pg9.0/share/postgresql/contrib/postgis-1.5: Permission denied
> PGHOME=/home/sachin/pg9.0
> Anything I am missing here?
Pozdrowienia,
Wojciech Strzalka
