[postgis-users] newbie query question
Mike Toews mwtoews at gmail.com
Wed Jun 9 12:02:04 PDT 2010
You could also use the EXCEPT set operator:
SELECT * FROM tbl_nla
EXCEPT
JOIN tbl_rvb ON ST_DWithin(tbl_nla.the_geom, tbl_rvb.the_geom, 100);
-Mike
On 9 June 2010 11:19, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> That's actually a surprisingly tricky question (to solve efficiently).
> The approach I have usually used is the counterintuitive one: do a
> left join on the positive constraint (*is* within 100 meters) and the
> return the rows that did *not* match the join (and therefore have null
> unique id values in the resultant).
> SELECT tbl_nla.gid FROM
> tbl_nla LEFT JOIN tbl_rvb
> WHERE tbl_rvb.gid IS NULL;
> P.
> On Wed, Jun 9, 2010 at 2:06 PM, G. van Es <gves2000 at yahoo.com> wrote:
>> I have two tables. tbl_nla has points as geometry and tbl_rvb has multipolygons.
>> We want to list all the points of tbl_nla with no objects of tbl_rvb within 100 metres.
>> Can anyone point me in the right direction?
>> Thanks,
>> Ge
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
