[postgis-users] newbie query question
Nick Bower nick at petangent.net
Wed Jun 9 16:27:29 PDT 2010
For ensuring there are no cloud occurences in a given roi I used
except at first then realised "having" combined with count/groupby was
the key.
Having 0 occurence or in our case having maximum pixels clear - same
either way.
These queries get thorny - sqlalchemy orm made things alot easier for
us becauses chances are that your having subquery needs to be joined
to something for additional criteria.
On 10/06/2010, at 5:02 AM, Mike Toews <mwtoews at gmail.com> wrote:
> You could also use the EXCEPT set operator:
> SELECT * FROM tbl_nla
> EXCEPT
> JOIN tbl_rvb ON ST_DWithin(tbl_nla.the_geom, tbl_rvb.the_geom, 100);
> -Mike
> On 9 June 2010 11:19, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> That's actually a surprisingly tricky question (to solve
>> efficiently).
>> The approach I have usually used is the counterintuitive one: do a
>> left join on the positive constraint (*is* within 100 meters) and the
>> return the rows that did *not* match the join (and therefore have
>> null
>> unique id values in the resultant).
>> SELECT tbl_nla.gid FROM
>> tbl_nla LEFT JOIN tbl_rvb
>> WHERE tbl_rvb.gid IS NULL;
>> P.
>> On Wed, Jun 9, 2010 at 2:06 PM, G. van Es <gves2000 at yahoo.com> wrote:
>>> I have two tables. tbl_nla has points as geometry and tbl_rvb has
>>> multipolygons.
>>> We want to list all the points of tbl_nla with no objects of
>>> tbl_rvb within 100 metres.
>>> Can anyone point me in the right direction?
>>> Thanks,
>>> Ge
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
