[postgis-users] Shapefile GUI loader
Paul Ramsey pramsey at opengeo.org
Fri Jun 11 05:51:06 PDT 2010
(a) ensure you have the gtk libs and devel support packages installed
(gtk+-dev) including pkg-config
(b) ./configure including the --with-gui directive
P
On Fri, Jun 11, 2010 at 7:12 AM, Bruno Friedmann <bruno at ioda-net.ch> wrote:
> Hi Regina, may I ask a question about building this under linux ?
> Have you already try it ( it seems based on gtk ) ?
> Any advice or ideas how to try the compilation is welcome.
> On 06/10/2010 12:07 AM, Paragon Corporation wrote:
>> There are usually 2 reasons why it doesn't show
>> 1) You are using PgAdmin III that is not under PostgreSQL.  The plugins.ini
>> that gets installed gets installed in the PgAdmin III that comes with
>> PostgreSQL.  Easy fix is to copy the plugins.ini from PostgreSQL /pgAdminIII
>> to the one you are using
>> 2) Your bin folder of PgAdminIII is pointing at an older install.
>> <http://www.postgresonline.com/journal/index.php?/archives/145-PgAdmin-III-P
>> lug-in-Registration-PostGIS-Shapefile-and-DBF-Loader.html>
>> Details here
>> http://www.postgis.us/screencast_postgis_gui_shapeloader
>> and
>> here
>> http://www.postgresonline.com/journal/index.php?/archives/145-PgAdmin-III-Pl
>> Leo and Regina
>>   _____
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tahir
>> Tamba
>> Sent: Wednesday, June 09, 2010 4:04 PM
>> To: postgis-users at postgis.refractions.net
>> Subject: [postgis-users] Shapefile GUI loader
>> Hi,
>> I've installed PostgreSQL 8.4.4  and PostGIS 1.5.1 on Windows XP, using
>> Windows installer version and installed PostGIS on top of PostgreSQL with
>> stackbuilder by accepting shape loader install during the install process.
>> Unfortunatly when I started pgAdmin III the Shapefile GUI loader is missing.
>> Can anyone tell me what is going on ?
>> Thank
>     Bruno Friedmann
> postgis-users mailing list
