[postgis-users] Shapefile GUI loader
Bruno Friedmann
bruno at ioda-net.ch
Fri Jun 11 06:36:37 PDT 2010
Thanks Paul for the informations.
I'm trying to localized the sources about that in svn but didn't find them yet
Did you have a pointer ?
Regards.
On 06/11/2010 02:51 PM, Paul Ramsey wrote:
> (a) ensure you have the gtk libs and devel support packages installed
> (gtk+-dev) including pkg-config
> (b) ./configure including the --with-gui directive
> P
> On Fri, Jun 11, 2010 at 7:12 AM, Bruno Friedmann <bruno at ioda-net.ch> wrote:
>> Hi Regina, may I ask a question about building this under linux ?
>> Have you already try it ( it seems based on gtk ) ?
>> Any advice or ideas how to try the compilation is welcome.
>> On 06/10/2010 12:07 AM, Paragon Corporation wrote:
>>> There are usually 2 reasons why it doesn't show
>>> 1) You are using PgAdmin III that is not under PostgreSQL. The plugins.ini
>>> that gets installed gets installed in the PgAdmin III that comes with
>>> PostgreSQL. Easy fix is to copy the plugins.ini from PostgreSQL /pgAdminIII
>>> to the one you are using
>>> 2) Your bin folder of PgAdminIII is pointing at an older install.
>>> <http://www.postgresonline.com/journal/index.php?/archives/145-PgAdmin-III-P
>>> lug-in-Registration-PostGIS-Shapefile-and-DBF-Loader.html>
>>> Details here
>>> http://www.postgis.us/screencast_postgis_gui_shapeloader
>>> and
>>> here
>>> http://www.postgresonline.com/journal/index.php?/archives/145-PgAdmin-III-Pl
>>> Leo and Regina
>>> _____
>>> From: postgis-users-bounces at postgis.refractions.net
>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tahir
>>> Tamba
>>> Sent: Wednesday, June 09, 2010 4:04 PM
>>> To: postgis-users at postgis.refractions.net
>>> Subject: [postgis-users] Shapefile GUI loader
>>> Hi,
>>> I've installed PostgreSQL 8.4.4 and PostGIS 1.5.1 on Windows XP, using
>>> Windows installer version and installed PostGIS on top of PostgreSQL with
>>> stackbuilder by accepting shape loader install during the install process.
>>> Unfortunatly when I started pgAdmin III the Shapefile GUI loader is missing.
>>> Can anyone tell me what is going on ?
>>> Thank
Bruno Friedmann
