[postgis-users] Converting a LineString to MultiPoint
Mike Toews
mwtoews at gmail.com
Thu Jun 17 16:50:05 PDT 2010
Or, if you have version < 1.5, you could use a simple WKT hack to text
replace 'LINESTRING' with 'MULTIPOINT', since the rest is the same:
SELECT gid, ST_AsText(replace(ST_AsEWKT(geom), 'LINESTRING',
'MULTIPOINT')::geometry)
FROM
(SELECT 1 as gid, 'LINESTRING (0 0, 0 3, 3 4)'::geometry AS geom
UNION ALL
SELECT 2 as gid, 'LINESTRING (1 1, 2 6, 7 7)'::geometry AS geom) AS g;
Again, this is a complete hack, and assumes you have all LINESTRING
types. I use ST_AsEWKT in case you have more than 3 dimensions and/or
an SRID.
-Mike
On 17 June 2010 16:36, Mike Toews <mwtoews at gmail.com> wrote:
> If you have PostGIS 1.5, then you can use ST_DumpPoints:
> http://postgis.refractions.net/docs/ST_DumpPoints.html
> E.g.:
> SELECT gid, ST_AsText(ST_Collect(ST_AsText(geom)))
> FROM (
> SELECT gid, (ST_DumpPoints(g.geom)).*
> FROM
> UNION ALL
> ) j
> GROUP BY gid;
> -Mike
> On 17 June 2010 14:57, Andrea Peri 2007 <aperi2007 at gmail.com> wrote:
>> Hi,
>> I have a table of LineStrings, and need to create a table of MultiPoints,
>> where every multipoint is using the same vertex of a LineString.
>> There is a method to do this using only sql ?
>> Thx,
>> Andrea.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
