[postgis-users] Converting a LineString to MultiPoint
Andrea Peri
aperi2007 at gmail.com
Sat Jun 19 05:44:59 PDT 2010
HI Mike,
it work very well.
So I reached my scope.
I used this sql:
INSERT INTO public.<table_name multipoint> (id,idrtt,geom) (
select
c.id,
c.idrtt,
st_union(c.geom)
from (
select
a.id as id,
a.idrtt as idrtt,
(ST_DumpPoints(a.geom)).* as geom
from
public.<table_name linestring> as a
) as c
group by
c.id,
c.idrtt
Regards,
Andrea.
>If you have PostGIS 1.5, then you can use ST_DumpPoints:
>http://postgis.refractions.net/docs/ST_DumpPoints.html <http://postgis.refractions.net/docs/ST_DumpPoints.html>
>E.g.:
>SELECT gid, ST_AsText(ST_Collect(ST_AsText(geom)))
>FROM (
> SELECT gid, (ST_DumpPoints(g.geom)).*
> FROM
> (SELECT 1 as gid, 'LINESTRING (0 0, 0 3, 3 4)'::geometry AS geom
> UNION ALL
> SELECT 2 as gid, 'LINESTRING (1 1, 2 6, 7 7)'::geometry AS geom) AS g
> ) j
>GROUP BY gid;
>-Mike
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100619/0462c08f/attachment.html>
