[postgis-users] Unable to build PostGIS 1.4.2 on MacOS 10.6.4
Paul Ramsey
pramsey at opengeo.org
Wed Jun 23 17:26:49 PDT 2010
OS/X includes it's own iconv, and somehow you're getting a conflict
based on the software you've installed. It looks like you've compiled
against GNU libiconv (hence 'libiconv_open') but are linking against
OSX iconv (which uses plain 'iconv_open').
Hope that helps you track things. Watch what ./configure picks up when
you run it.
P
On Wed, Jun 23, 2010 at 5:16 PM, Guyren G Howe <gisborne at emailuser.net> wrote:
> I had no trouble installing 1.5, but finding out that our project was using 1.4, I did the same steps (presuming I had all the requirements just fine). But make gives me this:
> make -C loader
> gcc -g -O2 -fno-common -DPIC -Wall -Wmissing-prototypes shpopen.o dbfopen.o getopt.o shp2pgsql.o ../liblwgeom/liblwgeom.a -liconv -lm -o shp2pgsql
> Undefined symbols:
> "_libiconv_open", referenced from:
> _utf8 in shp2pgsql.o
> "_libiconv_close", referenced from:
> "_libiconv", referenced from:
> ld: symbol(s) not found
> collect2: ld returned 1 exit status
> I've installed libiconv, but this hasn't helped. Grateful any assistance.
> postgis-users mailing list
