[postgis-users] error messages upgrading to 1.5.0
P Kishor
punk.kish at gmail.com
Tue Mar 2 17:14:55 PST 2010
I upgraded to Postgis 1.5.0, but in the process, encountered the
following messages that might have left my install on shaky grounds.
Hopefully someone can shed some light on what is going on here. Thanks
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:57:
NOTICE: type "spheroid" is not yet defined
DETAIL: Creating a shell type definition.
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:63:
NOTICE: argument type spheroid is only a shell
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:68:
NOTICE: return type spheroid is only a shell
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:73:
CREATE FUNCTION
CREATE TYPE
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:90:
NOTICE: type "geometry" is not yet defined
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:96:
NOTICE: argument type geometry is only a shell
CREATE FUNCTION
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:108:
NOTICE: return type geometry is only a shell
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:114:
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:119:
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:124:
CREATE FUNCTION
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:134:
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:139:
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7744:
NOTICE: aggregate geomunion(geometry) does not exist, skipping
DROP AGGREGATE
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7745:
NOTICE: aggregate st_geomunion(geometry) does not exist, skipping
DROP AGGREGATE
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7746:
NOTICE: aggregate accum_old(geometry) does not exist, skipping
DROP AGGREGATE
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7747:
NOTICE: aggregate st_accum_old(geometry) does not exist, skipping
DROP AGGREGATE
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7750:
NOTICE: function box2d_overleft(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7751:
NOTICE: function box2d_overright(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7752:
NOTICE: function box2d_left(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7753:
NOTICE: function box2d_right(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7754:
NOTICE: function box2d_contain(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7755:
NOTICE: function box2d_contained(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7756:
NOTICE: function box2d_overlap(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7757:
NOTICE: function box2d_same(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7758:
NOTICE: function box2d_intersects(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7759:
NOTICE: function st_box2d_overleft(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7760:
NOTICE: function st_box2d_overright(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7761:
NOTICE: function st_box2d_left(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7762:
NOTICE: function st_box2d_right(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7763:
NOTICE: function st_box2d_contain(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7764:
NOTICE: function st_box2d_contained(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7765:
NOTICE: function st_box2d_overlap(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7766:
NOTICE: function st_box2d_same(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7767:
NOTICE: function st_box2d_intersects(box2d,box2d) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7768:
NOTICE: function st_addbbox(geometry) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7769:
NOTICE: function st_dropbbox(geometry) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7770:
NOTICE: function st_hasbbox(geometry) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7771:
NOTICE: function cache_bbox() does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7772:
NOTICE: function st_cache_bbox() does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7773:
NOTICE: function
transform_geometry(geometry,text,text,pg_catalog.int4) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7774:
NOTICE: function collector(geometry,geometry) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7775:
NOTICE: function st_collector(geometry,geometry) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7776:
NOTICE: function geom_accum(geometry[],geometry) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7777:
NOTICE: function st_geom_accum(geometry[],geometry) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7778:
NOTICE: function collect_garray(geometry[]) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7779:
NOTICE: function st_collect_garray(geometry[]) does not exist,
skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7780:
NOTICE: function geosnoop(geometry) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7781:
NOTICE: function jtsnoop(geometry) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7782:
NOTICE: function st_noop(geometry) does not exist, skipping
DROP FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7783:
NOTICE: function st_max_distance(geometry,geometry) does not exist,
skipping
DROP FUNCTION
Puneet Kishor
