[postgis-users] error messages upgrading to 1.5.0
Paul Ramsey pramsey at opengeo.org
Tue Mar 2 17:19:42 PST 2010
All notices, non-harmful. We recognize that this amount of noise is
probably counter-productive...
http://trac.osgeo.org/postgis/ticket/415
On Tue, Mar 2, 2010 at 5:14 PM, P Kishor <punk.kish at gmail.com> wrote:
> Hi,
> I upgraded to Postgis 1.5.0, but in the process, encountered the
> following messages that might have left my install on shaky grounds.
> Hopefully someone can shed some light on what is going on here. Thanks
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:57:
> NOTICE:  type "spheroid" is not yet defined
> DETAIL:  Creating a shell type definition.
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:63:
> NOTICE:  argument type spheroid is only a shell
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:68:
> NOTICE:  return type spheroid is only a shell
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:73:
> CREATE FUNCTION
> CREATE TYPE
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:90:
> NOTICE:  type "geometry" is not yet defined
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:96:
> NOTICE:  argument type geometry is only a shell
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:108:
> NOTICE:  return type geometry is only a shell
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:114:
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:119:
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:124:
> CREATE FUNCTION
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:134:
> CREATE FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:139:
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7744:
> NOTICE:  aggregate geomunion(geometry) does not exist, skipping
> DROP AGGREGATE
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7745:
> NOTICE:  aggregate st_geomunion(geometry) does not exist, skipping
> DROP AGGREGATE
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7746:
> NOTICE:  aggregate accum_old(geometry) does not exist, skipping
> DROP AGGREGATE
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7747:
> NOTICE:  aggregate st_accum_old(geometry) does not exist, skipping
> DROP AGGREGATE
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7750:
> NOTICE:  function box2d_overleft(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7751:
> NOTICE:  function box2d_overright(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7752:
> NOTICE:  function box2d_left(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7753:
> NOTICE:  function box2d_right(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7754:
> NOTICE:  function box2d_contain(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7755:
> NOTICE:  function box2d_contained(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7756:
> NOTICE:  function box2d_overlap(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7757:
> NOTICE:  function box2d_same(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7758:
> NOTICE:  function box2d_intersects(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7759:
> NOTICE:  function st_box2d_overleft(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7760:
> NOTICE:  function st_box2d_overright(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7761:
> NOTICE:  function st_box2d_left(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7762:
> NOTICE:  function st_box2d_right(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7763:
> NOTICE:  function st_box2d_contain(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7764:
> NOTICE:  function st_box2d_contained(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7765:
> NOTICE:  function st_box2d_overlap(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7766:
> NOTICE:  function st_box2d_same(box2d,box2d) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7767:
> NOTICE:  function st_box2d_intersects(box2d,box2d) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7768:
> NOTICE:  function st_addbbox(geometry) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7769:
> NOTICE:  function st_dropbbox(geometry) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7770:
> NOTICE:  function st_hasbbox(geometry) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7771:
> NOTICE:  function cache_bbox() does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7772:
> NOTICE:  function st_cache_bbox() does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7773:
> NOTICE:  function
> transform_geometry(geometry,text,text,pg_catalog.int4) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7774:
> NOTICE:  function collector(geometry,geometry) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7775:
> NOTICE:  function st_collector(geometry,geometry) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7776:
> NOTICE:  function geom_accum(geometry[],geometry) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7777:
> NOTICE:  function st_geom_accum(geometry[],geometry) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7778:
> NOTICE:  function collect_garray(geometry[]) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7779:
> NOTICE:  function st_collect_garray(geometry[]) does not exist,
> skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7780:
> NOTICE:  function geosnoop(geometry) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7781:
> NOTICE:  function jtsnoop(geometry) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7782:
> NOTICE:  function st_noop(geometry) does not exist, skipping
> DROP FUNCTION
> psql:/usr/local/pgsql/share/contrib/postgis-1.5/postgis.sql:7783:
> NOTICE:  function st_max_distance(geometry,geometry) does not exist,
> skipping
> DROP FUNCTION
> Puneet Kishor
> postgis-users mailing list
