[postgis-users] postgis_comments.sql installation location?
Greg Troxel gdt at ir.bbn.com
Fri Mar 5 16:15:17 PST 2010
I have updated the pkgsrc package for postgis to 1.5.0 and make check
passes (on NetBSD i386).  (There is still considerable ickiness in the
pkgsrc package because I haven't resolved the libtool integration
fully.)
postgis_comments.sql looks like it is installed in:
  comments-install: comments
	cp postgis_comments.sql $(PGSQL_SHAREDIR)/contrib/postgis_comments.sql
which is inconsistent with the rest of the .sql files which are
versioned.
Currently pkgsrc installs postgis_comments.sql manually along with some
other docs (to avoid depending on the doc tools) and we end up with:
  /usr/pkg/share/postgresql/contrib/postgis-1.5/postgis.sql
  /usr/pkg/share/postgresql/contrib/postgis-1.5/postgis_upgrade_13_to_15.sql
  /usr/pkg/share/postgresql/contrib/postgis-1.5/postgis_upgrade_14_to_15.sql
  /usr/pkg/share/postgresql/contrib/postgis-1.5/postgis_upgrade_15_minor.sql
  /usr/pkg/share/postgresql/contrib/postgis-1.5/spatial_ref_sys.sql
  /usr/pkg/share/postgresql/contrib/postgis-1.5/uninstall_postgis.sql
  /usr/pkg/share/postgresql/contrib/postgis_comments.sql
Is that right?  Should I put postgis_comments.sql someplace else?
Should doc/Makefile.in put it someplace else?
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100305/ec0c9a6f/attachment.pgp>
