[postgis-users] postgis_comments.sql installation location?
Paragon Corporation
lr at pcorp.us
Fri Mar 5 23:02:34 PST 2010
Greg,
It should go under postgis-1.5 folder since its version specific.
I'll put this in as a ticket item. I don't use postgis_comments install for
making so probably missed it.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Greg
Troxel
Sent: Friday, March 05, 2010 7:15 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] postgis_comments.sql installation location?
I have updated the pkgsrc package for postgis to 1.5.0 and make check passes
(on NetBSD i386). (There is still considerable ickiness in the pkgsrc
package because I haven't resolved the libtool integration
fully.)
postgis_comments.sql looks like it is installed in:
comments-install: comments
cp postgis_comments.sql
$(PGSQL_SHAREDIR)/contrib/postgis_comments.sql
which is inconsistent with the rest of the .sql files which are versioned.
Currently pkgsrc installs postgis_comments.sql manually along with some
other docs (to avoid depending on the doc tools) and we end up with:
/usr/pkg/share/postgresql/contrib/postgis-1.5/postgis.sql
/usr/pkg/share/postgresql/contrib/postgis-1.5/postgis_upgrade_13_to_15.sql
/usr/pkg/share/postgresql/contrib/postgis-1.5/postgis_upgrade_14_to_15.sql
/usr/pkg/share/postgresql/contrib/postgis-1.5/postgis_upgrade_15_minor.sql
/usr/pkg/share/postgresql/contrib/postgis-1.5/spatial_ref_sys.sql
/usr/pkg/share/postgresql/contrib/postgis-1.5/uninstall_postgis.sql
/usr/pkg/share/postgresql/contrib/postgis_comments.sql
Is that right? Should I put postgis_comments.sql someplace else?
Should doc/Makefile.in put it someplace else?
