[postgis-users] Make install failure in PostGIS-1.5.1
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Mar 12 05:32:10 PST 2010
Sachin Srivastava wrote:
> Hi all,
> I am building postgis-1.5.1 with (proj 4.7.0, geos-3.2.0 and
> pg9.0alpha4) on linux (centos5 32 bit).
> make is successful, however in make install i am getting this error:
> /bin/sh
> /home/sachin/pgsql/lib/postgresql/pgxs/src/makefiles/../../config/install-sh
> -c -d '/home/sachin/pgsql/lib/postgresql'
> '/home/sachin/pgsql/share/postgresql/contrib/postgis-1.5'
> make[1]: /home/sachin/pgsql/share/postgresql/contrib/postgis-1.5: No
> such file or directory
> make[1]: *** [installdirs] Error 1
> make: *** [postgis-install] Error 2
> Anything i am missing?
Hi Sachin,
No, it's a bug :( The PGXSOVERRIDE code to support versioned directory
installation under older versions of PostgreSQL had not been updated to
check for version 9.0 rather than 8.5. I've fixed this in SVN for both
1.5 branch and trunk, but you should be able to apply the attached patch
and then re-run "autoconf" to generate a new configure file that should
work correctly.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
Type: text/x-diff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100312/b42e3a57/attachment.patch>
