[postgis-users] Read file encoding from from shape file
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Sat Mar 13 12:11:50 PST 2010
Paul Ramsey wrote:
> I was never certain that ESRI software actually respected the DBF code
> page flags, but your reference indicates they do, so this seems
> reasonable. Some investigation of the current state of shapelib WRT
> encoding would be wise, as I think we should update our shapelib to
> the current version when we release 2.0.
> P.
Indeed, shapelib supports from some time, now:
Citing the change log in dbfopen.c:
* Revision 1.77 2007/12/15 20:25:21 bram
* dbfopen.c now reads the Code Page information from the DBF file, and
exports
* this information as a string through the DBFGetCodePage function.
This is
* either the number from the LDID header field ("LDID/<number>") or as the
* content of an accompanying .CPG file. When creating a DBF file, the
code can
* be set using DBFCreateEx.
Regards,
Peter
> On Fri, Feb 26, 2010 at 5:55 AM, Peter Hopfgartner
> <peter.hopfgartner at r3-gis.com> wrote:
>> Hi
>> Looking into the sources of shp2pgsql, [0], it seems that the loader assumes
>> that the encoding of the dbf file is "WINDOWS-1252", if not specified
>> differently by the -W command line option.
>> From [1], shape files carry some information about their encoding, either in
>> the dbf file header at byte position 29, [2], or in a separate file with
>> extension CPG.
>> Would it make sense to change the default behaviour of shp2pgsql into:
>> 1) try to get file encoding from dbf file or cpg file
>> 2) if 1) fails, take WINDOWS-1252 as default
>> 3) if -W is given, take this option
>> And then, is the information about the encoding set by pgsql2shp? It would
>> be smooth, if shapes generated by pgsql2shp could be imported by shp2pgsql
>> without specifying any encoding during import ("just works").
>> Regards,
>> Peter
>> [0] http://trac.osgeo.org/postgis/browser/trunk/loader/
>> [1]
>> http://support.esri.com/index.cfm?fa=knowledgebase.techArticles.articleShow&d=21106
>> [2] http://www.dbase.com/knowledgebase/int/db7_file_fmt.htm
>> Dott. Peter Hopfgartner
>> R3 GIS Srl - GmbH
>> Via Johann Kravogl-Str. 2
>> I-39012 Meran/Merano (BZ)
>> Email: peter.hopfgartner at r3-gis.com
>> Tel. : +39 0473 494949
>> Fax : +39 0473 069902
>> www : http://www.r3-gis.com
>> XING : http://www.xing.com/go/invita/8917535
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
R3 GIS Srl - GmbH
