[postgis-users] ERROR after geos install
Pedro Monteiro monteiro.s.pedro at gmail.com
Mon Mar 15 04:51:37 PDT 2010
Thank you all.
I've solved the problem creating the biddings on ld.so.conf (don't know why
they desapeared)
         echo '/usr/local/lib' >> /etc/ld.so.conf.d/local-lib.conf
         ldconfig
And my postgis instance is working again.
2010/3/15 strk <strk at keybit.net>
> On Mon, Mar 15, 2010 at 12:54:33AM -0100, Pedro Monteiro wrote:
> > Hi, I'm writing to ask for help with some misbehaviour of my postgis
> > database, after installing geos from EPEL on a Centos 5.2 server, getting
> > this error.
> > "ERROR: could not load library "/usr/local/lib/liblwgeom.so":
> > libgeos_c.so.1: cannot open shared object file: No such file or
> directory"
> Try running ldconfig, as root.
> Make sure /usr/local/lib is in your /etc/ld.so.conf
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100315/19a1f52f/attachment.html>
