[postgis-users] Proj on centos 5.2
Paul Ramsey
pramsey at opengeo.org
Mon Mar 15 10:57:54 PDT 2010
What does "from base repositories" mean? If you compiled from source,
and you had proj-devel installed, it would pick up your system proj
library. Perhaps you haven't installed proj-devel?
P
On Mon, Mar 15, 2010 at 10:50 AM, Pedro Monteiro
<monteiro.s.pedro at gmail.com> wrote:
> Hi, I've installed Postgis from the base repositories and when I try to run
> ST_Transform queries it returns this ERROR:
> ERROR: PostGIS transform() called, but support not compiled in. Modify your
> makefile to add proj support, remake and re-install
> Proj rpm is installed,version 4.4.8
> Does anyone know the solution for this errors?
> Thak you in advance.
> Pedro
> postgis-users mailing list
