[postgis-users] Proj on centos 5.2
Pedro Monteiro monteiro.s.pedro at gmail.com
Mon Mar 15 11:11:54 PDT 2010
I've not compiled it from source, Postgis it's working except functions
related to proj.I
've been checking my installation and postgis was installed via yum from
EPEL repositories and proj from centos base repositories.
Pedro
2010/3/15 Paul Ramsey <pramsey at opengeo.org>
> What does "from base repositories" mean? If you compiled from source,
> and you had proj-devel installed, it would pick up your system proj
> library. Perhaps you haven't installed proj-devel?
> P
> On Mon, Mar 15, 2010 at 10:50 AM, Pedro Monteiro
> <monteiro.s.pedro at gmail.com> wrote:
> > Hi, I've installed Postgis from the base repositories and when I try to
> run
> > ST_Transform queries it returns this ERROR:
> > ERROR: PostGIS transform() called, but support not compiled in. Modify
> your
> > makefile to add proj support, remake and re-install
> > Proj rpm is installed,version 4.4.8
> > Does anyone know the solution for this errors?
> > Thak you in advance.
> > Pedro
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100315/46aa05c5/attachment.html>
