[postgis-users] Proj on centos 5.2
Paul Ramsey
pramsey at opengeo.org
Mon Mar 15 11:18:19 PDT 2010
Then the answer is as simple as the error message: whoever packaged
those postgis RPMs did so without including support for proj. The RPMS
from the PGDG include proj support.
http://yum.pgsqlrpms.org/8.4/
On Mon, Mar 15, 2010 at 11:11 AM, Pedro Monteiro
<monteiro.s.pedro at gmail.com> wrote:
> I've not compiled it from source, Postgis it's working except functions
> related to proj.I
> 've been checking my installation and postgis was installed via yum from
> EPEL repositories and proj from centos base repositories.
> Pedro
> 2010/3/15 Paul Ramsey <pramsey at opengeo.org>
>> What does "from base repositories" mean? If you compiled from source,
>> and you had proj-devel installed, it would pick up your system proj
>> library. Perhaps you haven't installed proj-devel?
>> P
>> On Mon, Mar 15, 2010 at 10:50 AM, Pedro Monteiro
>> > Hi, I've installed Postgis from the base repositories and when I try to
>> > run
>> > ST_Transform queries it returns this ERROR:
>> > ERROR: PostGIS transform() called, but support not compiled in. Modify
>> > your
>> > makefile to add proj support, remake and re-install
>> > Proj rpm is installed,version 4.4.8
>> > Does anyone know the solution for this errors?
>> > Thak you in advance.
>> > Pedro
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
