[postgis-users] Proj on centos 5.2
Devrim GÜNDÜZ
devrim at gunduz.org
Mon Mar 15 12:57:02 PDT 2010
On Mon, 2010-03-15 at 16:50 -0100, Pedro Monteiro wrote:
> Hi, I've installed Postgis from the base repositories and when I try
> to run
> ST_Transform queries it returns this ERROR:
> ERROR: PostGIS transform() called, but support not compiled in. Modify
> your
> makefile to add proj support, remake and re-install
> Proj rpm is installed,version 4.4.8
Umm, IIRC proj 4.4.8 is not shipped in any CentOS or EPEL repositories
You may want to switch using http://yum.pgrpms.org -- it has better
integration, and has more up2date packages.
Regards,
Devrim GÜNDÜZ
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
PostgreSQL RPM Repository: http://yum.pgrpms.org
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100315/32c4da16/attachment.pgp>
