[postgis-users] Proj on centos 5.2
Pedro Monteiro
monteiro.s.pedro at gmail.com
Tue Mar 16 04:09:18 PDT 2010
Yes, you are right, I've been digging around and my proj is installed via
rpm from remotesensing.org.
Is there any tutorial that I can follow to move to
http://yum.pgrpms.org/and upgrade my postgres databases.
Thank you all.
2010/3/15 Devrim GÜNDÜZ <devrim at gunduz.org>
> On Mon, 2010-03-15 at 16:50 -0100, Pedro Monteiro wrote:
> > Hi, I've installed Postgis from the base repositories and when I try
> > to run
> > ST_Transform queries it returns this ERROR:
> > ERROR: PostGIS transform() called, but support not compiled in. Modify
> > your
> > makefile to add proj support, remake and re-install
> > Proj rpm is installed,version 4.4.8
> Umm, IIRC proj 4.4.8 is not shipped in any CentOS or EPEL repositories
> You may want to switch using http://yum.pgrpms.org -- it has better
> integration, and has more up2date packages.
> Regards,
> Devrim GÜNDÜZ
> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
> PostgreSQL RPM Repository: http://yum.pgrpms.org
> Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
> http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100316/d2fc9922/attachment.html>
