[postgis-users] PostGIS/PostGres Configuration
Paul Ramsey
pramsey at cleverelephant.ca
Tue Mar 16 17:30:36 PDT 2010
Steffan,
Is your bigger file by any chance actually bigger than 2GB in any of
its components? Large (>2GB) files are not currently supported in
release, though we do have a patch on the issue in the tracker.
P
On Tue, Mar 16, 2010 at 5:15 PM, Steffan Chmuryk <schmuryk at icisociety.ca> wrote:
> Thank you for your help Paul;
> I have successfully loaded a dataset, a 30mb administrative boundaries file. I have also viewed this information successfully. Now I am trying to load a larger, 2gb, file. Using the shp2pgsql tool, I have encountered an error:
> An unhandled win32 exception occurred in shp2pgsql-gui.exe [3996]. Just-in-Time debugging this exception failed with the following error: No installed debugger has Just-In-Time debugging enabled.
> So I installed a new debugger, the WinDbg debugger, and executed it; however, now I am not getting an error message, and my data is still not being loaded to postgis/postgre. I then modified the data execution prevention to work only for windows programs. Still haven't gotten anywhere.
> I am using the shp2pgsql tool by itself, am I missing a step?
> Steffan Chmuryk
> Technical Services Coordinator, ICIS
> www.icisociety.ca
> Office: (250) 381-9295
> Cell: (250) 516-2481
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Monday, March 15, 2010 8:38 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS/PostGres Configuration
> From an unrelated post on udig-devel it looks like the error you are
> seeing is common to the most recent 1.2M release... try backing up to
> the last 1.1 release and using that for PostGIS access.
> Also, if you're doing general desktop tests, you could try gvSIG,
> CadCorp SIS and (!!) MapInfo's latest release.
> P.
> On Mon, Mar 15, 2010 at 5:30 PM, Steffan Chmuryk <schmuryk at icisociety.ca> wrote:
>> Thanks,
>> So now, I have set up the connection, and have tried to connect via all three applications. Here are the errors:
>> * Udig will connect, and seems to load the data, but then gives this message: RenderingException(s) occurred during rendering: Must call hasNext before calling next
>> *Seems to be a java error.
>> * OpenJump connects to the db, but gives this message: Error: syntax error at or near "ST_GeomFromText" (PSQL Exception)
>> *Seems to require a plugin.
>> * QGIS seems to work fine.
>> More to come...
>> Steffan Chmuryk
>> www.icisociety.ca
>> Sent: Monday, March 15, 2010 12:15 PM
>> Steffan,
>> Leave your localhost entry in place, it's useful. Make a copy of the
>> line and edit the copy.
>> Change localhost to 192.168.0.0 and change 32 to 16.
>> Ensure that listen_addresses = '*' in your postgresql.conf file.
>> Restart the database
>> Try again.
>> P
>> On Mon, Mar 15, 2010 at 11:50 AM, Steffan Chmuryk
>>> Hello,
>>> This is my first post, so please go easy ;)
>>> I have built a PostGIS/PostGres spatial database, and have successfully
>>> imported a shapefile. Now when I try to connect to the database via
>>> Udig, OpenJump, or Qgis, I the following error:
>>> Fatal: no pg_hba.conf entry for host "192.168.x.xxx", user "postgres",
>>> database "postgis1', SSL off (PSQL Exception)
>>> Now I have tried every combination of the following:
>>> * Edit pg_hba.conf so that the default 127.0.0.1/32 is replaced by the
>>> 192... ip
>>> * Add another access configuration to the file, so that the 192... ip,
>>> the postgres user, and the database are all included
>>> * Enable the SSL off configuration in the postgres.conf file, and
>>> restart the machine
>>> * I have even explored the JDBC stuff... argh!
>>> The error message in the application (Udig, OpenJump, or Qgis) does not
>>> change. But upon changing the files to reflect any of the above
>>> configurations, I am then unable to connect to the db within pgadminIII,
>>> due to an error in loading the pg_hba.conf file.
>>> Regarding the environment:
>>> * Server used to host MSSQL and SDE;
>>> * Server is Windows Server 2003 (not R2);
>>> Steffan Chmuryk
>>> www.icisociety.ca
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> No virus found in this incoming message.
>> Checked by AVG - www.avg.com
>> Version: 9.0.733 / Virus Database: 271.1.1/2748 - Release Date: 03/15/10 00:33:00
> Version: 9.0.733 / Virus Database: 271.1.1/2748 - Release Date: 03/15/10 12:33:00
