[postgis-users] PostGIS/PostGres Configuration
Paul Ramsey
pramsey at cleverelephant.ca
Tue Mar 16 17:38:35 PDT 2010
Steffan, could you try passing the smaller of the two datasets through
the commandline shp2pgsql tool?
shp2pgsql -s 3005 -D thefile.shp thetable > thefile.sql
See if it goes boom...
P
On Tue, Mar 16, 2010 at 5:21 PM, Steffan Chmuryk <schmuryk at icisociety.ca> wrote:
> Thanks,
> Actually, I have been working with two datasets. One of which is 470mb total, and the other is 2.27gb total; however, both of these shapefiles encounter the same issues. The 470mb data is an addressing dataset, point based, and the 2.27gb file is a cadastre dataset, polygon based.
> Steffan Chmuryk
> Technical Services Coordinator, ICIS
> www.icisociety.ca
> Office: (250) 381-9295
> Cell: (250) 516-2481
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Tuesday, March 16, 2010 5:31 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS/PostGres Configuration
> Steffan,
> Is your bigger file by any chance actually bigger than 2GB in any of
> its components? Large (>2GB) files are not currently supported in
> release, though we do have a patch on the issue in the tracker.
> P
> On Tue, Mar 16, 2010 at 5:15 PM, Steffan Chmuryk <schmuryk at icisociety.ca> wrote:
>> Thank you for your help Paul;
>> I have successfully loaded a dataset, a 30mb administrative boundaries file. I have also viewed this information successfully. Now I am trying to load a larger, 2gb, file. Using the shp2pgsql tool, I have encountered an error:
>> An unhandled win32 exception occurred in shp2pgsql-gui.exe [3996]. Just-in-Time debugging this exception failed with the following error: No installed debugger has Just-In-Time debugging enabled.
>> So I installed a new debugger, the WinDbg debugger, and executed it; however, now I am not getting an error message, and my data is still not being loaded to postgis/postgre. I then modified the data execution prevention to work only for windows programs. Still haven't gotten anywhere.
>> I am using the shp2pgsql tool by itself, am I missing a step?
>> Steffan Chmuryk
>> www.icisociety.ca
>> Sent: Monday, March 15, 2010 8:38 PM
>> From an unrelated post on udig-devel it looks like the error you are
>> seeing is common to the most recent 1.2M release... try backing up to
>> the last 1.1 release and using that for PostGIS access.
>> Also, if you're doing general desktop tests, you could try gvSIG,
>> CadCorp SIS and (!!) MapInfo's latest release.
>> P.
>> On Mon, Mar 15, 2010 at 5:30 PM, Steffan Chmuryk <schmuryk at icisociety.ca> wrote:
>>> Thanks,
>>> So now, I have set up the connection, and have tried to connect via all three applications. Here are the errors:
>>> * Udig will connect, and seems to load the data, but then gives this message: RenderingException(s) occurred during rendering: Must call hasNext before calling next
>>> *Seems to be a java error.
>>> * OpenJump connects to the db, but gives this message: Error: syntax error at or near "ST_GeomFromText" (PSQL Exception)
>>> *Seems to require a plugin.
>>> * QGIS seems to work fine.
>>> More to come...
>>> Steffan Chmuryk
>>> www.icisociety.ca
>>> Sent: Monday, March 15, 2010 12:15 PM
>>> Steffan,
>>> Leave your localhost entry in place, it's useful. Make a copy of the
>>> line and edit the copy.
>>> Change localhost to 192.168.0.0 and change 32 to 16.
>>> Ensure that listen_addresses = '*' in your postgresql.conf file.
>>> Restart the database
>>> Try again.
>>> P
>>> On Mon, Mar 15, 2010 at 11:50 AM, Steffan Chmuryk
>>>> Hello,
>>>> This is my first post, so please go easy ;)
>>>> I have built a PostGIS/PostGres spatial database, and have successfully
>>>> imported a shapefile. Now when I try to connect to the database via
>>>> Udig, OpenJump, or Qgis, I the following error:
>>>> Fatal: no pg_hba.conf entry for host "192.168.x.xxx", user "postgres",
>>>> database "postgis1', SSL off (PSQL Exception)
>>>> Now I have tried every combination of the following:
>>>> * Edit pg_hba.conf so that the default 127.0.0.1/32 is replaced by the
>>>> 192... ip
>>>> * Add another access configuration to the file, so that the 192... ip,
>>>> the postgres user, and the database are all included
>>>> * Enable the SSL off configuration in the postgres.conf file, and
>>>> restart the machine
>>>> * I have even explored the JDBC stuff... argh!
>>>> The error message in the application (Udig, OpenJump, or Qgis) does not
>>>> change. But upon changing the files to reflect any of the above
>>>> configurations, I am then unable to connect to the db within pgadminIII,
>>>> due to an error in loading the pg_hba.conf file.
>>>> Regarding the environment:
>>>> * Server used to host MSSQL and SDE;
>>>> * Server is Windows Server 2003 (not R2);
>>>> Steffan Chmuryk
>>>> www.icisociety.ca
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> No virus found in this incoming message.
>>> Checked by AVG - www.avg.com
>>> Version: 9.0.733 / Virus Database: 271.1.1/2748 - Release Date: 03/15/10 00:33:00
>> Version: 9.0.733 / Virus Database: 271.1.1/2748 - Release Date: 03/15/10 12:33:00
