[postgis-users] GEOS intersects() threw an error!
Paul Ramsey
pramsey at opengeo.org
Wed Mar 17 08:57:08 PDT 2010
Very reasonable... ticket that as an enhancement please!
http://trac.osgeo.org/postgis
p
On Wed, Mar 17, 2010 at 8:54 AM, Jerry Carter <jerry at jerrycarter.org> wrote:
> Thanks. I've already started down that path.
> The real issue in my mind is the error text. If GEOS throws an error, couldn't PostGIS internally run the equivalent of ST_IsValidReason() on the geometry before writing a message? Seeing 'GEOS intersects() threw an error due do an invalid geometry (self-intersection)' seems much more helpful than the current message.
> -=- Jerry
> On Mar 17, 2010, at 11:51 AM, Mike Toews wrote:
>> Typically, this type of geometry error is fixed using
>> ST_Buffer(the_geom,0). So just wrap your geometry in that zero buffer,
>> and you should get a valid geometry (in ST_IsValid) and a correct
>> ST_Intersects result.
>> -Mike
>> On 17 March 2010 08:23, Jerry Carter <jerry at jerrycarter.org> wrote:
>>> I am aware that this geometry reports a Self-intersection according to ST_IsValidReason().
> postgis-users mailing list
