[postgis-users] GEOS intersects() threw an error!
Mike Toews
mwtoews at gmail.com
Wed Mar 17 09:09:30 PDT 2010
With POSTGIS="2.0.0SVN" GEOS="3.3.0-CAPI-1.6.1" I see the error, as
you reported.
But primarily I use POSTGIS="1.3.6" GEOS="3.1.0-CAPI-1.5.0" which
gives me first an informative NOTICE followed by an ERROR:
NOTICE: TopologyException: side location conflict -164.924 60.9199
CONTEXT: SQL function "st_intersects" statement 1
ERROR: GEOS intersects() threw an error!
********** Error **********
SQL state: XX000
Context: SQL function "st_intersects" statement 1
It seems this NOTICE feature has slipped out of the recent versions.
-Mike
On 17 March 2010 08:54, Jerry Carter <jerry at jerrycarter.org> wrote:
> Thanks. I've already started down that path.
> The real issue in my mind is the error text. If GEOS throws an error, couldn't PostGIS internally run the equivalent of ST_IsValidReason() on the geometry before writing a message? Seeing 'GEOS intersects() threw an error due do an invalid geometry (self-intersection)' seems much more helpful than the current message.
> -=- Jerry
