[postgis-users] ERROR: array size exceeds the maximum	allowed(134217727)
    Paragon Corporation
    lr at pcorp.us
    Sat Mar 20 08:32:35 PDT 2010
Paul,
I doubt array size limit is the issue.  He said when he left the where
condition out it worked.  I would think it would definitely blow up in that
case.
Mike,
The issue from before was that array aggregate functions did not handle
NULLs correctly.  64-bit systems were more likely to segfault or give
strange
Errros in this case.
To rule out that we still have some of these issues in the code base,  can
you add a
geom IS NOT NULL
Condition to your WHERE filter.  If that works, then the NULL issue is
probably still lurking somewhere.
Leo and Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Saturday, March 20, 2010 10:56 AM
To: PostGIS Users Discussion; mgleahy at alumni.uwaterloo.ca
Subject: Re: [postgis-users] ERROR: array size exceeds the maximum
allowed(134217727)
Actually, memunion does the opposite, it passes the resultant and preserves
mem. The default behavior is fast-but-memory-hungry. And has been for some
time, though in different forms. There were some bugs in the array handling
code, but Mark CA killed most of them, so the latest 1.5 and 1.4 streams
should be good. If it's possible that the issue is one of array size, maybe
Mike could find the dial that controls that maximum, and turn it up and down
and see if it makes his problem go away/happen sooner.
P.
On Sat, Mar 20, 2010 at 7:41 AM, strk <strk at keybit.net> wrote:
> On Sat, Mar 20, 2010 at 05:49:42AM -0400, Mike Leahy wrote:
>> Hello again,
>> It might be of interest to point out that substituting st_union()
>> with
>> st_memunion() seems to have worked around this.  I'm curious though,
>> because there is not a great deal of data being processed, and I am
>> running this on a fairly sturdy system that that has more capacity
>> than some of the Fedora systems I'm running.
> st_memunion builds a big array with all geometries in it..
> you were hitting a limit of the array type.
> st_union should behave better.
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-users mailing list
