[postgis-users] ERROR: array size exceeds the maximum allowed(134217727)
Mike Leahy mgleahy at alumni.uwaterloo.ca
Sat Mar 20 11:00:59 PDT 2010
Hi Leo/Regina,
Thanks for the suggestion.  I tried adding the clause 'not geom is null' to
the where statement in each of the two sub-queries that have the
st_union(geom) functions are used, but it still segfaults.
I also tried this on a fresh database with very little data, and it doesn't
seem to cause problems.  But I have two databases with live data where I can
cause this.  I have been able to pare one of these down to remove personal
information and reduce unnecessary data, while still generating the crash with
that query.   Would someone be interested in a dump of this db?  Of course,
that someone would ideally be able to test this on a 64-bit (K)ubutnu system,
in the hopes that the problem can be replicated.
Mike
On Saturday 20 March 2010 11:32:35 Paragon Corporation wrote:
> Paul,
> I doubt array size limit is the issue.  He said when he left the where
> condition out it worked.  I would think it would definitely blow up in that
> case.
> Mike,
> The issue from before was that array aggregate functions did not handle
> NULLs correctly.  64-bit systems were more likely to segfault or give
> strange
> Errros in this case.
> To rule out that we still have some of these issues in the code base,  can
> you add a
> geom IS NOT NULL
> Condition to your WHERE filter.  If that works, then the NULL issue is
> probably still lurking somewhere.
> Leo and Regina
> http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Saturday, March 20, 2010 10:56 AM
> To: PostGIS Users Discussion; mgleahy at alumni.uwaterloo.ca
> Subject: Re: [postgis-users] ERROR: array size exceeds the maximum
> allowed(134217727)
> Actually, memunion does the opposite, it passes the resultant and preserves
> mem. The default behavior is fast-but-memory-hungry. And has been for some
> time, though in different forms. There were some bugs in the array handling
> code, but Mark CA killed most of them, so the latest 1.5 and 1.4 streams
> should be good. If it's possible that the issue is one of array size, maybe
> Mike could find the dial that controls that maximum, and turn it up and
>  down and see if it makes his problem go away/happen sooner.
> P.
> On Sat, Mar 20, 2010 at 7:41 AM, strk <strk at keybit.net> wrote:
> > On Sat, Mar 20, 2010 at 05:49:42AM -0400, Mike Leahy wrote:
> >> Hello again,
> >> It might be of interest to point out that substituting st_union()
> >> with
> >> st_memunion() seems to have worked around this.  I'm curious though,
> >> because there is not a great deal of data being processed, and I am
> >> running this on a fairly sturdy system that that has more capacity
> >> than some of the Fedora systems I'm running.
> > st_memunion builds a big array with all geometries in it..
> > you were hitting a limit of the array type.
> > st_union should behave better.
> > --strk;
> >  ()   Free GIS & Flash consultant/developer
> >  /\   http://strk.keybit.net/services.html
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
