[postgis-users] ERROR: array size exceeds the maximum allowed(134217727)
Paragon Corporation lr at pcorp.us
Sat Mar 20 14:53:24 PDT 2010
Mike,
We apologize, didn't notice this was in a subquery and that you have a limit
statement in your query.   So we presume regardless of your WHERE only 26
records are being selected.
So Paul could be right that you do have data that is hitting some compiled
or variable limit.
Does running the subquery alone work or you didn't try because it takes a
long time?
Thanks,
Leo and Regina
http://www.postgis.us
-----Original Message-----
From: Mike Leahy [mailto:mgl.gis at gmail.com] On Behalf Of Mike Leahy
Sent: Saturday, March 20, 2010 2:01 PM
To: Paragon Corporation
Cc: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] ERROR: array size exceeds the maximum
allowed(134217727)
Hi Leo/Regina,
Thanks for the suggestion.  I tried adding the clause 'not geom is null' to
the where statement in each of the two sub-queries that have the
st_union(geom) functions are used, but it still segfaults.
I also tried this on a fresh database with very little data, and it doesn't
seem to cause problems.  But I have two databases with live data where I can
cause this.  I have been able to pare one of these down to remove personal
information and reduce unnecessary data, while still generating the crash
with
that query.   Would someone be interested in a dump of this db?  Of course,
that someone would ideally be able to test this on a 64-bit (K)ubutnu
system, in the hopes that the problem can be replicated.
Mike
On Saturday 20 March 2010 11:32:35 Paragon Corporation wrote:
> Paul,
> I doubt array size limit is the issue.  He said when he left the where
> condition out it worked.  I would think it would definitely blow up in
> that case.
> Mike,
> The issue from before was that array aggregate functions did not
> handle NULLs correctly.  64-bit systems were more likely to segfault
> or give strange Errros in this case.
> To rule out that we still have some of these issues in the code base,
> can you add a
> geom IS NOT NULL
> Condition to your WHERE filter.  If that works, then the NULL issue is
> probably still lurking somewhere.
> Leo and Regina
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul Ramsey
> Sent: Saturday, March 20, 2010 10:56 AM
> To: PostGIS Users Discussion; mgleahy at alumni.uwaterloo.ca
> allowed(134217727)
> Actually, memunion does the opposite, it passes the resultant and
> preserves mem. The default behavior is fast-but-memory-hungry. And has
> been for some time, though in different forms. There were some bugs in
> the array handling code, but Mark CA killed most of them, so the
> latest 1.5 and 1.4 streams should be good. If it's possible that the
> issue is one of array size, maybe Mike could find the dial that
> controls that maximum, and turn it up and  down and see if it makes his
problem go away/happen sooner.
> P.
> On Sat, Mar 20, 2010 at 7:41 AM, strk <strk at keybit.net> wrote:
> > On Sat, Mar 20, 2010 at 05:49:42AM -0400, Mike Leahy wrote:
> >> Hello again,
> >> It might be of interest to point out that substituting st_union()
> >> with
> >> st_memunion() seems to have worked around this.  I'm curious
> >> though, because there is not a great deal of data being processed,
> >> and I am running this on a fairly sturdy system that that has more
> >> capacity than some of the Fedora systems I'm running.
> > st_memunion builds a big array with all geometries in it..
> > you were hitting a limit of the array type.
> > st_union should behave better.
> > --strk;
> >  ()   Free GIS & Flash consultant/developer
> >  /\   http://strk.keybit.net/services.html
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
