[postgis-users] ERROR: array size exceeds themaximumallowed(134217727)
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 22 14:15:58 PDT 2010
Mike,
See if this patch makes anything better. It matches tlane's changes to
the 8.4 agg finalfunc.
P.
On Mon, Mar 22, 2010 at 1:29 PM, Greg Stark <gsstark at mit.edu> wrote:
> On Mon, Mar 22, 2010 at 4:45 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> Did you already try replacing your postgis functions with array_agg
>> calls to see if we can push the problem back over the fence to pgsql
>> land?
> On Sat, Mar 20, 2010 at 9:17 AM, Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
>> Running this query on various data will produce one of two results. One is
>> the error mentioned in the subject (ERROR: array size exceeds the maximum
>> allowed (134217727)). I can find very little information on this error. The
>> other outcome is that it often causes the PostgreSQL backend to segfault (see
>> gdboutput.txt).
> gdboutput.txt:
> Program terminated with signal 11, Segmentation fault.
> #0 0x00007fa4be23615b in pfree () from
> /usr/lib/postgresql/8.4/bin/postgres
> #1 0x00007fa4be18091b in makeMdArrayResult () from
> #2 0x00007fa4b7f038bc in pgis_accum_finalfn () from
> /usr/lib/postgresql/8.4/lib/postgis-1.5.so
> #3 0x00007fa4b7f039ee in pgis_geometry_union_finalfn () from
> Any chance you can generate one of these seg faults from a build with
> symbols and with assertions enabled? It might catch the problem
> earlier and provide more info.
> IIRC there were some memory management changes which required changes
> to array_agg() and which had some risk of causing problems for other
> sites with similar coding. Is it possible your'e missing some of these
> changes? I'm having trouble tracking them all down but at least
> there's these:
> commit 3d332de2eab8a01c0ef3f58ea69de2010fe8a1e1
> Author: Tom Lane <tgl at sss.pgh.pa.us>
> Date: Thu Jul 23 20:45:27 2009 +0000
> In a non-hashed Agg node, reset the "aggcontext" at group
> boundaries, instead
> of individually pfree'ing pass-by-reference transition values. This should
> be at least as fast as the prior coding, and it has the major advantage of
> clearing out any working data an aggregate function may have stored in or
> underneath the aggcontext. This avoids memory leakage when an aggregate
> such as array_agg() is used in GROUP BY mode. Per report from Chris Spotts.
> Back-patch to 8.4. In principle the problem could arise in prior versions,
> but since they didn't have array_agg the issue seems not critical.
> commit 7f83b61cc26eeac0c5a09add49f6cf899f87fc0b
> Date: Sat Jun 20 18:45:28 2009 +0000
> Fix things so that array_agg_finalfn does not modify or free its input
> ArrayBuildState, per trouble report from Merlin Moncure. By adopting
> this fix, we are essentially deciding that aggregate final-functions
> should not modify their inputs ever. Adjust documentation and comments
> to match that conclusion.
> greg
> postgis-users mailing list
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100322/9e175b4b/attachment.obj>
