[postgis-users] ERROR: array size exceeds themaximumallowed(134217727)
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 22 14:27:18 PDT 2010
This looks like a winner, at least insofar as it removes the max array
error condition for me in OS/X. Huge thanks to Greg Stark for digging
up the references to Tom Lane's changes in the array agg stuff...
On Mon, Mar 22, 2010 at 2:15 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Mike,
> See if this patch makes anything better. It matches tlane's changes to
> the 8.4 agg finalfunc.
> P.
> On Mon, Mar 22, 2010 at 1:29 PM, Greg Stark <gsstark at mit.edu> wrote:
>> On Mon, Mar 22, 2010 at 4:45 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> Did you already try replacing your postgis functions with array_agg
>>> calls to see if we can push the problem back over the fence to pgsql
>>> land?
>> On Sat, Mar 20, 2010 at 9:17 AM, Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
>>> Running this query on various data will produce one of two results. One is
>>> the error mentioned in the subject (ERROR: array size exceeds the maximum
>>> allowed (134217727)). I can find very little information on this error. The
>>> other outcome is that it often causes the PostgreSQL backend to segfault (see
>>> gdboutput.txt).
>> gdboutput.txt:
>> Program terminated with signal 11, Segmentation fault.
>> #0 0x00007fa4be23615b in pfree () from
>> /usr/lib/postgresql/8.4/bin/postgres
>> #1 0x00007fa4be18091b in makeMdArrayResult () from
>> #2 0x00007fa4b7f038bc in pgis_accum_finalfn () from
>> /usr/lib/postgresql/8.4/lib/postgis-1.5.so
>> #3 0x00007fa4b7f039ee in pgis_geometry_union_finalfn () from
>> Any chance you can generate one of these seg faults from a build with
>> symbols and with assertions enabled? It might catch the problem
>> earlier and provide more info.
>> IIRC there were some memory management changes which required changes
>> to array_agg() and which had some risk of causing problems for other
>> sites with similar coding. Is it possible your'e missing some of these
>> changes? I'm having trouble tracking them all down but at least
>> there's these:
>> commit 3d332de2eab8a01c0ef3f58ea69de2010fe8a1e1
>> Author: Tom Lane <tgl at sss.pgh.pa.us>
>> Date: Thu Jul 23 20:45:27 2009 +0000
>> In a non-hashed Agg node, reset the "aggcontext" at group
>> boundaries, instead
>> of individually pfree'ing pass-by-reference transition values. This should
>> be at least as fast as the prior coding, and it has the major advantage of
>> clearing out any working data an aggregate function may have stored in or
>> underneath the aggcontext. This avoids memory leakage when an aggregate
>> such as array_agg() is used in GROUP BY mode. Per report from Chris Spotts.
>> Back-patch to 8.4. In principle the problem could arise in prior versions,
>> but since they didn't have array_agg the issue seems not critical.
>> commit 7f83b61cc26eeac0c5a09add49f6cf899f87fc0b
>> Date: Sat Jun 20 18:45:28 2009 +0000
>> Fix things so that array_agg_finalfn does not modify or free its input
>> ArrayBuildState, per trouble report from Merlin Moncure. By adopting
>> this fix, we are essentially deciding that aggregate final-functions
>> should not modify their inputs ever. Adjust documentation and comments
>> to match that conclusion.
>> greg
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
