[postgis-users] transformation discrepancy with postgis v. cs2cs
Bryan Keith
bryan at ideotrope.org
Fri Mar 26 07:09:15 PDT 2010
> On 25 March 2010 14:28, Bryan Keith <bryan at ideotrope.org> wrote:
>> Hmmm, for my original post I did the cs2cs check on a different machine.
>> When I run the cs2cs transformation on the machine that's running
>> postgis,
>> then I get the same result that postgis returns. Does this mean that
>> cs2cs isn't finding the grid shift files either? Or does it mean that
>> it's using the wrong grid shift files? Or?
>> Bryan
> Something is definitely strange with the PROJ.4 installation on that
> one system. If I had to guess, you compiled PROJ.4 yourself, but
> didn't unzip the gridshift files in the nad folder before ./configure
> ? It should be apparent that the grid shift files are installed with
> the make install command.
Mike,
Thanks for the reply.
I certainly don't think I compiled anything myself. I'm on Ubuntu/Debian
and installed postgres, postgis, gdal, and the gdal/ogr Python bindings
with apt-get. I don't know that I ever explicitly installed proj.4, but I
figured it was installed because I have the cs2cs executable. I've
installed some other GIS-type stuff like Quantum.
> Try reinstalling the PROJ.4 library with the gridshift files intact,
> and it should affect both PostGIS and cs2cs (since they use the same
> system library).
Should I just try:
sudo apt-get install proj
Bryan
> -Mike
> postgis-users mailing list
