[postgis-users] transformation discrepancy with postgis v. cs2cs
Bryan Keith
bryan at ideotrope.org
Fri Mar 26 08:51:53 PDT 2010
>> Something is definitely strange with the PROJ.4 installation on that
>> one system. If I had to guess, you compiled PROJ.4 yourself, but
>> didn't unzip the gridshift files in the nad folder before ./configure
>> ? It should be apparent that the grid shift files are installed with
>> the make install command.
> Mike,
> Thanks for the reply.
> I certainly don't think I compiled anything myself. I'm on Ubuntu/Debian
> and installed postgres, postgis, gdal, and the gdal/ogr Python bindings
> with apt-get. I don't know that I ever explicitly installed proj.4, but I
> figured it was installed because I have the cs2cs executable. I've
> installed some other GIS-type stuff like Quantum.
>> Try reinstalling the PROJ.4 library with the gridshift files intact,
>> and it should affect both PostGIS and cs2cs (since they use the same
>> system library).
> Should I just try:
> sudo apt-get install proj
I tried this and got the message:
proj is already the newest version.
proj set to manually installed.
Manually installed? I wonder why that is.
Where is it installed? I search for a nad directory and only found this one:
/usr/lib/grass/etc/nad
I didn't try doing the coordinate conversion in GRASS since I don't know
how to use GRASS, but the nad directory seems to have the uncompressed
grid shift files:
-rw-r--r-- 1 root root 1053896 2008-05-29 14:33 alaska
-rw-r--r-- 1 root root 264392 2008-05-29 14:33 conus
-rw-r--r-- 1 root root 8840 2008-05-29 14:33 FL
-rw-r--r-- 1 root root 451976 2008-05-29 14:33 hawaii
-rw-r--r-- 1 root root 3528 2008-05-29 14:33 MD
-rw-r--r-- 1 root root 1113184 2008-05-29 14:33 ntv1_can.dat
-rw-r--r-- 1 root root 318464 2008-05-29 14:33 nzgd2kgrid0005.gsb
-rw-r--r-- 1 root root 26696 2008-05-29 14:33 prvi
-rw-r--r-- 1 root root 59176 2008-05-29 14:33 stgeorge
-rw-r--r-- 1 root root 26696 2008-05-29 14:33 stlrnc
-rw-r--r-- 1 root root 7016 2008-05-29 14:33 stpaul
-rw-r--r-- 1 root root 4392 2008-05-29 14:33 TN
-rw-r--r-- 1 root root 6728 2008-05-29 14:33 WI
-rw-r--r-- 1 root root 11080 2008-05-29 14:33 WO
I appreciate any suggestions. I don't really know what I'm doing here.
Bryan
> Bryan
>> -Mike
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
