[postgis-users] Nested loop join = very bad performance
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Mar 29 04:53:50 PDT 2010
Mike Leahy wrote:
> Is this something that should be looked into, or should I just incorporate the
> workaround of disabling nested loop joins into my code?
I find that generally PostgreSQL is fairly good at its estimates unless
someone has already tried to tune the database. Have you changed any of
the settings in postgresql.conf from their defaults?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
