[postgis-users] Nested loop join = very bad performance
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Mon Mar 29 14:35:29 PDT 2010
Hi Mark,
I don't recall making any changes...at least not until the error I encountered
last week cropped up - but I think I reversed those changes (I will double-
check tonight). But I think I have encountered performance problems with this
query before on other systems - I had originally dismissed it as hardware
limitations I was dealing in my testing system at the time. After recent
hardware upgrades and after dealing with that specific bug, that's when the
slow performance of this query really stood out.
Mike
On Monday 29 March 2010 07:53:50 Mark Cave-Ayland wrote:
> Mike Leahy wrote:
> > Is this something that should be looked into, or should I just
> > incorporate the workaround of disabling nested loop joins into my code?
> I find that generally PostgreSQL is fairly good at its estimates unless
> someone has already tried to tune the database. Have you changed any of
> the settings in postgresql.conf from their defaults?
> ATB,
> Mark.
