[postgis-users] shp2pgsql in quite mode????...(shp2pgsql -q)???
Nicolas Gillet - MARKET-IP
nicolas.gillet at market-ip.com
Mon Mar 29 06:18:42 PDT 2010
Hello,
Indeed there is no -q.
But are you sure that it actually is shp2pgsql that you want to quiet down
? (there are at most 15 lines)
I think that what can annoy you is the output from the psql that usually is
piped behind shp2pgsql.
Psql do have a -q parameter.
e.g. :
shp2pgsql -W utf-8 -s 4326 -d -I /path/to/some/shp my_table | psql -q -d
my_database -h host -U user
Thats the command I used most of the time.
If you really want to remove shp2pgsql output I think that your only option
is using something like command > null to redirect the ouput nowhere.
Hope this helps.
Nicolas
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] De la part de
Shreerang Patwardhan
Envoyé : lundi 29 mars 2010 12:44
À : Pune GNU/Linux Users Group Mailing List; PostGIS Users Discussion
Objet : [postgis-users] shp2pgsql in quite mode????...(shp2pgsql -q)???
Hey all,
I do not wish to display the output of the command shp2pgsql at the
terminal. I want the command to run in quite mode. But there is no -q option
for shp2pgsql. How do I get around this issue?
Thanx,
Shreerang Patwardhan.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100329/cf143620/attachment.html>
