[postgis-users] How to change srid
Nicolas Gillet - MARKET-IP nicolas.gillet at market-ip.com
Tue Mar 30 00:05:00 PDT 2010
Hello,
Editing the geometry_column table is half part of the job.
You have to update the geometries too.
UPDATE table SET the_geom  = ST_SetSRID(the_geom, 4326).
Usually the SRID is -1 when you forget to set the srid when you import a shape file.
Hope this helps.
Nicolas.
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Marco Lechner - FOSSGIS e.V.
Envoyé : mardi 30 mars 2010 9:00
À : postgis-users at postgis.refractions.net
Objet : Re: [postgis-users] How to change srid
change the SRID in the geometry_columns table. There should be a corresponding recordset defining the SRID, geometry type, geometry column and so on of your table.
Marco
Am 30.03.2010 08:53, schrieb Marko Čubranić:
dear,
iv loaded data to postgis and for all geometry srid  is -1.
if i want to change srid without doing and transformations, can i do that and how?
Thank you,
Marko Cubranic
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100330/cb8f2400/attachment.html>
