[postgis-users] How to change srid
Marko Čubranić
mcubranic at gmail.com
Tue Mar 30 00:06:27 PDT 2010
thank you,
i think this will help me.
Marko
2010/3/30 Nicolas Gillet - MARKET-IP <nicolas.gillet at market-ip.com>
> Hello,
> Editing the geometry_column table is half part of the job.
> You have to update the geometries too.
> UPDATE table SET the_geom = ST_SetSRID(the_geom, 4326).
> Usually the SRID is -1 when you forget to set the srid when you import a
> shape file.
> Hope this helps.
> Nicolas.
> *De :* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *De la part de* Marco
> Lechner - FOSSGIS e.V.
> *Envoyé :* mardi 30 mars 2010 9:00
> *À :* postgis-users at postgis.refractions.net
> *Objet :* Re: [postgis-users] How to change srid
> change the SRID in the geometry_columns table. There should be a
> corresponding recordset defining the SRID, geometry type, geometry column
> and so on of your table.
> Marco
> Am 30.03.2010 08:53, schrieb Marko Čubranić:
> dear,
> iv loaded data to postgis and for all geometry srid is -1.
> if i want to change srid without doing and transformations, can i do that
> and how?
> Thank you,
> Marko Cubranic
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100330/18bc6e45/attachment.html>
