[postgis-users] Need a "polygon box" of a table instead of the bounding box that returns extent function
Martin Davis mbdavis at refractions.net
Mon May 3 09:14:56 PDT 2010
I believe that the convex hull of a set of lines is the same as the
convex hull of the vertices of the lines.  So it should do what you want.
But if you have a reference showing otherwise I'd be interested to see it.
Oscar Zamudio wrote:
> ha, ha!!,
> My knowledge come from Maths ,and certainly not from Postgis!. The concept
> of Convex Hull (in algorithms and math fields) is always applied to set of
> points and I remember there was a big challenge to find a good method for
> lines (some years ago). But I don't mind Math anymore, if this function
> works to solve my problem, it will be ok for me.
> I will let you know later about my results.
> On Mon, May 3, 2010 at 11:29 AM, strk <strk at keybit.net> wrote:
>> On Mon, May 03, 2010 at 11:18:03AM -0300, Oscar Zamudio wrote:
>>> Thanks strk,
>>> As far as I know convex hull basically applies to a collection of
>> points...,
>>> nevertheless, I will try with my set of lines.
>> How far does your knowledge come from ? :)
>> http://postgis.refractions.net/docs/ST_ConvexHull.html
>> --strk;
>>  ()   Free GIS & Flash consultant/developer
>>  /\   http://strk.keybit.net/services.html
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
