[postgis-users] PostGIS Installation Issues
Mike Toews
mwtoews at gmail.com
Tue May 4 12:47:16 PDT 2010
Here is an example from a shell (dash, the default for Ubuntu):
# (optional) Create a new empty database "mydb"
sudo -u postgres createdb mydb
# Add PL/pgSQL as a language
sudo -u postgres createlang plpgsql mydb
# Spatially enable it (from the 1.5 and 8.4 stocks, edit this
depending on which combinaiton you have):
sudo -u postgres psql -f
/usr/share/postgresql/8.4/contrib/postgis-1.5/postgis.sql mydb
/usr/share/postgresql/8.4/contrib/postgis-1.5/spatial_ref_sys.sql mydb
If you want to see the error messages in more detail, then add " 2>
myerrout" to the end of the last two commands above, then view the
myerrorout file afterwards.
-Mike
On 4 May 2010 12:32, yoda2nd <yoda2nd at niacc.org> wrote:
> Hello all,
> I have been trying to install PostGIS on Ubuntu Server for the last few
> days, however for some reason I can not get the SQL files (postgis.sql,
> spatial_ref_sys.sql, etc.) into the database. All I get is a screenfull
> of the following:
> psql:/gis/source_code/postgis-1.5.1/postgis/postgis.sql:7458: ERROR:
> current transaction is aborted, commands ignored until end of
> transaction block
> psql:/gis/source_code/postgis-1.5.1/postgis/postgis.sql:7465: ERROR:
> transaction block
> psql:/gis/source_code/postgis-1.5.1/postgis/postgis.sql:7472: ERROR:
> transaction block
> psql:/gis/source_code/postgis-1.5.1/postgis/postgis.sql:7478: ERROR:
> transaction block
> psql:/gis/source_code/postgis-1.5.1/postgis/postgis.sql:7485: ERROR:
> transaction block
> ./configure, make, make install all run fine without any errors that I
> can see. Any help would be much appreciated!
> Thanks
> yoda2nd
> postgis-users mailing list
