[postgis-users] encoding
Nicolas Ribot
nicolas.ribot at gmail.com
Thu May 6 07:31:38 PDT 2010
> Thanks Ralf,
> I don't understand how to use this.
> pgsql2shp -f myshape mydb -h localhost -P xxxx -u postgres mytable -export
> PGCLIENTENCODING=LATIN1 ????
> I'm using PostGIS 1.3.5 on an Windows-System
> Thanks
> Jo
You have to define an environment variable that will be used by PG
when exporting.
set PGCLIENTENCODING=LATIN1
then execute the plpgsql command
Nicolas
